Question about Western Digital Caviar SE WD800JD SATA Hard Drive
Cylinders 63 heads
How many cylinders
  • Western Digital Master
  • 10,291 Answers
16383 is usually the number.
Posted on Aug 16, 2017
I need to know the torque specs for the head gasket for a 99 2.2 pontiac sunfire
Install cylinder head bolts finger-tight. New cylinder head bolts are recommended due to stretch of the old bolts.
Tighten bolts in sequence, tighten the long bolts to 46 ft. lbs. (63 Nm) plue 90 degrees. Tighten the short bolts to 43 ft. lbs. (58 Nm)
Install pushrode and rocker arms and rocker arm nuts. Tighten nuts to 22 ft. lbs. (30 Nm).
Install valve cover and tighten bolts to 89 inch lbs. (10 Nm).
Apr 05, 2011 | 1999 Pontiac Sunfire
Need torque specs and bolt pattern for 96-2003 cavalar head gasket please send to mike@rstorage.net
Fig. 7: Location of the cylinder head retaining bolt holes
Fig. 13: Cylinder head bolt torque sequence for 2.2L engines
Tighten bolts in sequence, tighten the long bolts to 46 ft. lbs. (63 Nm) plue 90 degrees. Tighten the short bolts to 43 ft. lbs. (58 Nm) plue 90 degrees.
Hope helps.
Mar 18, 2011 | Chevrolet Cavalier Cars & Trucks
What are the head torque specs?
1996 Isuzu Truck Hombre 2.2L SFI 4cyl
Fig.: Cylinder head bolt torque sequence-2.2L engine
Apply a coating of 1052080 or equivalent sealer to the cylinder head bolt threads. Install the cylinder head bolts (within 15 minutes of sealer application), then tighten them in the proper sequence first to a torque of 46 ft. lbs. (63 Nm) for long bolts or to 43 ft. lbs. (58 Nm) for short bolts and then tighten all bolts an additional 90 degree turn using a torque angle meter.
Hope this helps (remember to rate this answer).
Jan 25, 2011 | 1996 Isuzu Hombre
Torque settings for a hyundai accent 1500 1998 model torque settings for head , conrods and crank
cylinder head bolt torque
52-55 ft lbs. cold engine
59-63 ft lbs. hot engine
connecting rod cap nut 26-28 ft lbs. SOHC
connecting rod cap nut 23-26 ft lbs. DOHC
main caps 41-44 ft lbs.
Dec 19, 2010 | Hyundai Motor 1998 Accent
'63 650 lost compression
yes your correct. It is most likely timeto resleeve the head and replace the pistons and rings, Both sides
Nov 24, 2009 | Pontiac Bonneville Cars & Trucks
Do you know the torque settings for the cylinder head bolts on a w reg daewoo matiz
Tighten the cylinder head bolts to 85--90 NSm (63--66lb-ft).
Nov 17, 2009 | 1999 Daewoo Lanos
Just transfered hard drive to another computer - in setup- need to know capacity, cylinders, heads, sectors
The specs are:
Capacity (unformatted/formatted):
20.00 GB / 15.02 GB
Cylinders: 16,383
Heads: 16
Sectors: 63
Here is a PDF w/specs
Fireball lct15
(http://www.dll.com.mx/biblioteca/HDD/Quantum/Fireball%20LCT15.pdf)
Hope this helps!
Sep 11, 2009 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Cylinder head daewoo matiz
Jun 06, 2009 | 1999 Daewoo Lanos
Quantium 10.2 gb fireball CX10A011 specs. ie sectors, mode, etc.
The specifications to enter the information manually, are on top of the harddrive. Kind of hard to discern, huh? That's because harddrive sizes from 6.4GB through 20.4GB are listed on top.
C/H/S = Cylinders/Heads/Sectors
The Quantum Fireball CX10A011 hardrive is a 10.2GB harddrive.
You will see -> C/H/S....10.2 - 16383/16/63 on top.
That is ,
16,383 Cylinders
16 Heads
63 Sectors
As for the 40GB model, it should be similar. If not, come back and post.
Jan 22, 2008 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
37 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
