Question about Nordic Track NordicTrack T6.1 Treadmill
New nordictrack t6.1 doesn't turn on - Nordic Track NordicTrack T6.1 Treadmill
Do all C1800s NordicTrack treadmill models use a safety key to turn on ?
The answer is yes you need a key. You also seriously need to read the manual before you use this machine.
https://www.manualowl.com/m/NordicTrack/C-1800s/Manual/341906
and this one for why and what could possibly go wrong - for your entertainment.
https://www.youtube.com/watch?v=qNPhVVjnoC0
Jan 29, 2015 | Nordic Track NordicTrack C 1800 Treadmill...
Treadmill not turning on properly
may need a new battery in the control head...
Jan 11, 2014 | Nordic Track NordicTrack C3000 Treadmill...
Nordictrack c2150 panel not working
adjust the Reed SWITCH, see the diagram attached it. Clean it, test it of open or faulty. Tight the connector very well. Replace and clean the contacts batteries( if they have).
Tight the ribbon cable inside.
If the problem persist, after you did, replace control display board
God bless you099b95f6-0273-44db-b9a8-431d1bfaedf5.gif242bb3fe-383b-4bdb-aa92-fe8728465711.gif
Jul 25, 2013 | Exercise & Fitness
My treadmill turns on, but doesn't start
1) LUBE the deck belt, this happen by lack of maintenance, maybe you have deck worn.
2) LUBE the rollers bearing too.
3) measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jul 23, 2012 | Nordic Track NordicTrack T7 si Treadmill
Treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Jun 02, 2012 | Exercise & Fitness
I have a nordictrack audiostrider 800 that i just replaced the console. now the resistance won't work. thoughts?
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Oct 19, 2011 | Nordic Track NordicTrack Treadmill, A2550
The resistance belt on my nordictrack 1300 woulnt tighten. How do I fix it? Thanks for you assistance.
When using the NordicTrack in manualmode, you can adjust its resistance by twisting a resistance knob, locatedeither in the corner of the console or on the upright support. If the treadmillbelt slips from side to side, you need to adjust its tension via bolts locatedin the back of the machine frame. First find the treadmill adjustmentbolts in the rear end of the treadmill frame, to either side of the belt. Now putin an Allen wrench into each bolt, one at a time, and turn each bolt aquarter-turn clockwise. Slip one hand among the belt and the treadmill deck. Ifthis doesn't pull the treadmill belt taut, it's still too loose. Tighten thebolts another quarter-turn. Continue testing the belt tension, then adjustingthe bolts as needed, until the belt is just loose enough for you to slip yourhand between it and the deck with no extra slack. Step onto the treadmill andwalk. The belt shouldn't bind or slip side to side. If it does, dismount andre-adjust the bolts until the belt tracks correctly. AV
Jun 11, 2011 | Exercise & Fitness
Nordic Track NordicTrack T6.1 Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
