Question about HP LaserJet 3015 All-In-One Printer
HP Laserjet M1319f PC Software Fax Receive/Send Log Hangs
The Problem: I've installed the fax machine on my computer running winxp 32bit sp3 and when i have received/send more than +- 30 faxes
the hp software hangs when i toggle between the send and receive log.
I've Testeded it on 4 Different PC's. There is only a setting for clearing the logs data files after 1 or more days but not the fax received/send log in the software.
Is there a Manual way of clearing the log files. and there does hp store the log information besides in the faxlog.xml file ?
Ajkill
  • 2035 Answers
SOURCE: HP6450 says fax log is full and cannot recieve or send.
  1. Press the Setup button (c01361401.giftools ).
  2. Press the Right arrow button (c01185072.jpg> ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg >) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button (c01185072.jpg> ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button (c01235250.gif ) to exit.
Posted on Jan 20, 2009
leroyal
  • 2120 Answers
SOURCE: cannot receive or send fax in a HP Laserjet 4101mfp
Plug a phone cord into the LINE port of the machine.
Posted on Mar 04, 2009
  • 102 Answers
SOURCE: multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Posted on Jul 04, 2009
  • 6 Answers
SOURCE: My HP J6480 All-in-One will fax out but I can't
look for auto answer button and press it .make sure the light is on .do one thing if the machine detect a fax tone press the start fax button. if it doesn't help then you need a fax module.
Posted on Jul 14, 2009
  • 199 Answers
SOURCE: hp officejet j6480 all in one printer
Clear the internal memory by clearing the fax log and memory
Posted on Oct 20, 2009
Testimonial: "Thank you, problem solved"
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
I have a Hp m1319f all in one printer/fax and we cannot send or recieve faxes at the moment. we have dsl hooked up to it and also when the number is dialed to the other fax machine, you can hear the other...
You state you are using DSL. Do you have a proper DSL filter on the line going to the fax machine. If not then the noise generated on the line by the DSL will cause fax send/receive issues.
Apr 04, 2011 | HP Laserjet M1319F Laser Multifunction...
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
Sending fax
FIXED WITH THE HELP OF HP GUY BY UPGRADING THE SOFTWARE IN TO THE MACHINE.
Jan 19, 2010 | HP Laserjet M1319F Laser Multifunction...
HP LASer jet m1319f mfp errors no entries in fax log
check that it is connected to the phone line, if your phone line is working your fax system also work
Jan 07, 2010 | HP Laserjet M1319F Laser Multifunction...
My HP M1319f fax machine is having trouble sending faxes only to certain phone numbers. Is this a problem with the actual machine, or the phone line?
I have purchased the HP M1319f multipurpose machine 1 year ago and expected it to print as well as fax. Sadly to say 1 year later, the printing works as expected but the fax never worked consistently for me. The solution I found was to buy a used fax machine and only use the HP M1319f as a printer.
The problem I've read about this problem on HP forums was the fax speed of the M1319f. It is locked to 28.8k which means it is only able to communicate with some fax machines. Older machines that doesn't support 28.8 will get errors and the fax will fail. This is definately an HP problem but considering I purchased this 1 year ago, this problem will never be fixed. Avoid this printer at all costs if your considering to use the fax machine.
Oct 19, 2009 | HP Laserjet M1319F Laser Multifunction...
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
