Question about Dacor ECD230 Epicure Electric Double Oven
Dacor double wall oven blows fuse when baking in high temp
its only when i use the lower oven, in broil or baking over 350. it tripps house fuse and wouldnt allow to pick up fuse till the oven has totally cooled down.
3 Suggested Answers
SOURCE: bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Posted on Feb 12, 2010
kojak18
  • 31 Answers
SOURCE: Dacor double oven ecd230 -- bottom oven won't heat
check the ignitor.
Posted on Jun 22, 2010
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Bake element
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor ECD230 Epicure Electric Double Oven Logo
108 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Jose Pino
Are you a Dacor Oven Expert? Answer questions, earn points and help others
