Question about Aerogrow AeroGarden
No Power When I plug in my 7 pod AeroGarden the grow lights will flash when the plug first enters the wall socket, but then nothing. If I reinsert the plug nothing will happen. If I use a differnt wall socket, the grow lights will flash again and then nothing. This just doesn't make any sense.
My light on my aerogarden wont come back on
we unplugged the aero garden to move to another room, when we plugged it in again the pump is running but the light didn't come back on. We check the lights and the connections and it still didn't go back on. Help Linda
Jul 16, 2010 | Aerogrow AeroGarden
Where is the fuse?
The fuse is located inside the base of the Aerogarden 7 on the main power board, and in fact there are 2 fuses. One large 2 Amp fuse, this is easily replaced. There is a second smaller fuse that is hard soddered onto the PCB and is more difficult to replace, but can be done if you have a soddering iron and some patience.
Apr 20, 2010 | Aerogrow International Inc. AEROGROW...
Lost owners manual need to reprogram the light
have you been to www.aerogarden.com. they have a troubleshooting area for the reprogramming of the lights.
Dec 30, 2009 | NRS AeroGarden 7-Pod Pro-100
Why did't my garden do well?
You can do either, if you purchase a new seed kit you know the varities have been tested and grow in an AeroGarden. If you plant yourself, but sure to look for small or dwarf varities and lean toward water loving plants.
What problems did you have with your other herbs, not basil?
Sep 29, 2009 | Aerogrow AeroGarden
I started my aerogarden 1 week ago today and 3 of the pods have not sprouted. i checked the seeds and they have not even started germinating. im getting nervous. This is the gourmet herb kit that comes...
well i recently also bought a aerogarden classic which i presume you to have it states in the aerogarden hand book in the master gardener kit ( which is a seperate seed kit purchase grow your own seed kit in other words! ) it states " even though great care and consideration is taken into producing the grow pods and selecting of seeds long transportation in humid or wet conditions may destry the seed" but this does not sound like you situation it clearly statets standard germination rate for a aergo garden is 4 days to rwo weeks tops you should also take into consideration if the size of seed some seeds have a greater tolerenace of water and need a bit more time for the water to germinate the seed regarding any more answers feel free to ask me on k_kv7@hotmail.co.uk
or easy enough read through this simple PDF its not relevant to the gourmet herb kit but the genral processes apply to all seed kits and gives you some good advice on all aspects from pruning to haarvesting and most challenging of all whe you have fruitnig crop how to polinate.
http://www.aerogarden.org.uk/files/Master%20Gardener%20Seed%20kit%20Guide.pdf
hope i was of help
Khawsar Alom
May 01, 2009 | NRS AeroGarden 7-Pod Pro-100
New oregano pod has mold fuzz
sounds like you have to much moister and not enough air flow, i would start over and place in a better air flow area..
Feb 13, 2009 | Aerogrow Aero Grow Aerogarden White
Dill & basil not growing
Hi kadoolittle, some pods do not sprout but can be return for a replacement.
Check out the Dill article on the Aerogardeners Wiki for more info on growing it in the Aerogarden.
http://aerogardeners.wikia.com/wiki/Dill
Jan 21, 2009 | Aerogrow AeroGarden
2wire HomePortal - green power light blinking
disconnect the power adapter. Reinsert the power adapter directly into the wall socket. Remove any power strips or surge protectors temporarily to ensure that these items are not preventing the 2wire's proper operation. make sure you are using the power adapter that came with the modem. Plug the power adapter into a different wall socket in another room.
Apr 07, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Aerogrow AeroGarden Logo
339 people viewed this question
Top Aerogrow Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Aerogrow Garden Expert? Answer questions, earn points and help others
