Question about Cycling
Saracen hoax gear drop out
What gear dropout bracket does the saracen hoax bike use
Windsor Wellington 2.0 serial number location on the bike
Serial numbers are typically on the underside of the bottom bracket (where the cranks go through the frame), on the left rear dropout (where the rear hub axle is attached to the frame) or sometimes on the bottom of the head tube (where fork goes through frame). Serial number is typically useful only for registering a bike in case of theft or for recalls.
Oct 17, 2016 | Windsor Cycling
Where is the serial # located?
Usually under bottom bracket (crank housing) or on outside of left rear dropout. Front of head tube may have a date code. Serial number is not very helpful with bikes. How to determine the year value etc of your bicycle
May 15, 2016 | Cycling
I'm trying to find the serial # for my 20 year old Murray bike
Look on outside of left rear dropout (where the wheel slides in) or under the bottom bracket (crank housing). Not very useful or important - your Murray is not collectible at all, parts do not depend on model year, and hard to get any info from serial number on a department store bike. How to determine the year value etc of your bicycle
Bike manuals
This is a specialized brand. your local bike shop can provide assistance
Aug 14, 2014 | Saracen Cycling
Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
Where is the serial number on a davinci chili pepper
On almost all bikes the serial number is either on the outside of the left rear dropout (where the axle sits) or under the bottom bracket (where the crank axle goes through the frame).
Mar 25, 2013 | Devinci Chili Pepper
Boulder 3 Mountain Bike..location of serial number
Serial Numbers are usually in one of two locations.
  1. Turn the bike upside down and look at what is the very bottom of the frame where the pedals and cranks pass through. This is the bottom bracket shell. Serial numbers are commonly stamped here and will be a long series of numbers and letters
  2. Occasionally they are also stamped inside the rear dropout on the left or right. The rear dropout is the part of the frame where the rear wheel is connected.
Matt @ roadragecycling.com
Oct 17, 2012 | Giant Bicycle Inc. Cycling
Where can i get a rear mech hanger for the saracen mantra 3?
According to my web search that would be a SRAM X5 medium cage 9 speed. Go surfing for one or call/visit your Local Bike Shop. I shop eBay a lot.
Sep 21, 2011 | Saracen Mantra 3
I loss my Serial number:
Most serial numbers are located on the bottom of the bike known as the bottom bracket. Too view the serial number flip the bike over and look between the crank arms on the bottom bracket. If the serial number is not visible it may be under a the guide for the cables and that will need to be loosened. Other places for a serial number, but much less common are the underneath of the rear stays or the rear dropouts.
Nov 15, 2010 | Cycling
Cant take off front wheel to change the inner tube on my saracen blitz 7005
I don't know the saracen blitz 7005 but some fork dropouts have retaining ridges on the inner face. You need to have slack fixings and pull the forks apart slightly to drop the wheel out.
Hope this helps.
Aug 22, 2009 | Cycling
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
