Question about Dell Dimension 9100 PC Desktop
Error 4 code for dell dimension 9100
When the PC is turned on I only get a the 4 lit in green. When I look at the codes, there is not anything listed for just the 4 lit
    Master:
  • Dell Master
  • 752 Answers
  • 3940 Answers
SOURCE: Dell Dimension 9100 will not power up
Most likely the power supply have failed. Although the system is getting some power to the Motherboard (Flea power indication on motherboard) there are at least 5 different voltages the power supply provides for the system. Losing any one can cause a no power situation like you describe.
A standard ATX power supply should resolve (It is the 1st item I'd replace, both because it is the 1st point of failure and the cheapest to replace)
Here is one ATX power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182030
Posted on Jun 13, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Dell Dimension 3000 Power Problems
You have one of two problems. Power supply bad or your heat sink has got to hot and has fried your processor
Posted on Feb 07, 2009
  • 81 Answers
SOURCE: blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Posted on Jun 16, 2009
  • 6 Answers
SOURCE: error after memory upgrade
the frequency of 256mb ram is nt equivalent to one gb ram
Posted on Jun 20, 2009
Vaio Tech
  • 166 Answers
SOURCE: I have a dimension 9100 that will not boot. I get
try a new cable for the hard drive and disk drive and see if no result try diferent hard drive please thanks
Posted on Oct 23, 2009
I have a dimension 5000 desktop, when I turn on I get a short burst on screen saying DELL, but then a blank screen. I hear a continuos beeping tone and all lightss on front of unit are dispalyed. Please...
Well if its a dell monitor also, it will say dell, and does not mean the computer is communicating with it, your manual is here ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-5000_Owner%27s%20Manual_en-us.pdf (copy and paste) what EXACTLY is the beeping code doing, the term continuous beeping tone could mean different things. You should have 4 small led lights on the rear that say A, B, C, and D that are diagnostic lights, what color are those?
Jan 06, 2014 | Dell Dimension 9100 PC Desktop
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
Oct 22, 2009 | Dell Dimension 9100 PC Desktop
Dell Dimension 9100 Blue Screen 0X00000024,00190293,86FA5B30,C000102,00000000. I tried to reinstall XP from CD and it says unable to locate Hard drive. Replaced Hard drive and tried again, same message....
Hope this help you...This is in relation to what your error code means, you'll need to check against the list.
  • Error 0x00000024 - This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
  • Error 0x00000004 - occurs because your computer processor detected and reported an unrecoverable hardware error to Windows
  • Error 0x0000007b - occurs if your computer is infected with a boot-sector virus.
  • Error 0x80004005 - occurs because the account that is being used to access the page does not have access to the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC registry key.
  • Error 0xc0000005 - occurs because of memory corruption.
  • Error 0xc0000034 - caused by a missing system file (usually Ntdll.dll in the %systemRoot%\system32 directory.
  • Error 0xc0000006 - occur if there is not enough free hard disk space on the NTFS-compressed hard disk partition when the SIS filter tries to read compressed back pointer data streams from the SIS volume.
Another common reason can be malware and spyware that penetrate to your computer registry and started destroying it... that's why it's so important you fix your registry right now!
trust this help.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Error after memory upgrade
Jun 20, 2009 | Dell Dimension 2400 PC Desktop
Blinking amber light with green 4 light
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
My Dell 9100 desktop won't start.
Hey mate... Now there could be a number of things wrong with your PC.. First thing is that on the back of the main tower there are 4 Lights that glow if the system is ok but in case of issues they glow in different patterns according to the potential problem... look out for those lights n refer em to this chart
http://support.dell.com/support/edocs/systems/dim9100/en/SM/adtshoot.htm#wp1054146
Also in case of potential component failtures the system gives out beep codes in patterns (maybe the sounds u hear at startup)... Do a quick check
Now regardless we can perform a basic troubleshooting...now you seem to be tech savy enough so do one thing... remove all the chords from the system... then hold dowm the power button to discharge the flea power... now remove all the components one by one n reseat them immediately... this will reset the connections n then try n restart again... if the problem persists then post the 4 led code here n we'll go from there mate :-)
Feb 11, 2009 | Dell Dimension 9100 PC Desktop
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Dell Dimension 8400 PC won't boot
http://www.computerhope.com/beep.htm
Here's a list of Boot Codes .....start with one stick of Ram
May 24, 2008 | Dell Dimension 8400 PC Desktop
Dell Dimension 9100 PC Desktop Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
