Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e studio 306 es showing message " Toner not recognized" so what to be done regarding this problem?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba Expert
  • 196 Answers
Replace toner chip
Posted on Jun 26, 2016
4 Suggested Answers
  • 13 Answers
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Posted on Jul 20, 2009
  • 628 Answers
SOURCE: toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
Posted on Sep 17, 2009
  • 9 Answers
SOURCE: We replace the used toner
There is a sensor just behind the waste toner box that sends beam through the water toner box to see if reaches the other side. If it does not, then the sensor thinks that the box is full. So you need to clean the waste toner box with some liquid cleaner so that it looks white from outside. Once the box is dry, try again. This should work now. Otherwise, there is problem with the sensor.
Posted on Sep 24, 2010
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
How to turn off the error message "Toner not recognized"?
Mkae sure contacts on cartridge and on machine are clean, use a pencil head eraser to clean.
Apr 18, 2014 | Toshiba E-Studio 306 Digital Copier
Service manual toshiba e-studio 306
can i get Service manual toshiba e-studio 306
Jan 29, 2013 | Refrigerators
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
Toshiba e-studio 211 copier .Toner sign not remove please halp me anwerali78@yahoo.com
Machine shows "Toner not Recognized" when correct toner is inserted into MFP.
It can be due to main PCB faulty.
May 28, 2011 | Toshiba Office Equipment & Supplies
Dear sir, my toshiba e studio machine some time showing "dispose used toner" . I thing that means tonner is finished. there have 4+1 toner which we need to replaces Idon,t know. Please help me
Dear,
your copier e-studio 350 some time showing '' dispose used toner'' It dont mean you install new toner... its mean you dispose used toner box.. Dear open the copier frant cover
and dispose used toner white box...
Thanks
Best Regards,
Aug 05, 2010 | Toshiba e-Studio 350 Copier
Copier Studio 55 Copier. Disposed of old toner and replaced with new toner. What a messy job. All done and the message is "join finisher to copier" Do not understand message. Please assist.
Hi how are you this is jack
Dear ,
you copier e-studio 65 showing message dispose of used toner.. ok.. Its donot mean dispose all old toner and install new toner... Its mean dispose used toner box... Dispose toner Box is a seprat box copier all garbage toner droped this box and when this box are full then copier showing message please dispose used toner box... please check it and dispose it.
Thanks
Aug 04, 2010 | Toshiba e-Studio65 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba e-Studio 232 Black and White Copier Logo
176 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
