Question about Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner
No vacum suction
No vacuum suction
    Top Expert:
  • Polaris Master
  • 8,175 Answers
Should be hooked to its own return from booster pump if pump on and filter pump on check filter on the wall fitting if ok make sure water flow from that fitting (should be in middle of pool from side to side) if pressure ok check to see if on inside if a hose came off if so put on and use zip tie to secure
Posted on Apr 23, 2016
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
Loss of suction in hose
your hose is blocked get some thing long and thin push it done the hose and try and clear it
Dec 17, 2013 | Dyson DC40 Multi floor Upright Vacuum...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Vacum shuts down when suction starts
Try turning the knob on the top of the vac all the way to the right.
Jul 04, 2010 | Electrolux Guardian Bagged Canister Vacuum
Does not have any suction to pick up
Clean out the filter in the top of the cyclone chamber
Make sure there are no blockages in the tubes or hoses by checking for vacuum
May 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The Hoover Windtunnel vacum will not pull suction
Either the machine or hose is blocked OR the filters are blocked.
Also possible that the belt is broken.
Please leave feedback
Thanks
Feb 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I just purchased a DC07 Dyson vacuum cleaner. It is not vacumming my floor - I have hardly any suction at all. Do I need to activate something in order to initiate the suction?
With vac upright suction is sent to the hose ie top of vac handle when handle is tilted down to the user vacuum position it should send the power suction to the floor also make sure collection bin it in securely that make be the problem
Sep 08, 2008 | Vacuums
Dyson Vacume dco7
Vacume overheated when inflow was plugged. Will it restart when it cools off.
Feb 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction
hey, how are you ?
here are a ew things that could be causing you sorrow
1.) Check your vacume to ensure that it isnt clogged anywhere
2.) before your compressor and after the filer, this part is where the suction takes place, check to see that it isnt clogged or that it isnt broken...
3.) check your packing (diapharam) in the vacume oto see if it ruptured(has a hole or broken)
4.) Check for lears on the vacume, basically run a pice of paper all over it and see if it is pulled to the vacume.
Once air is coming out the back, it means the compressor is working, but it alos means that the vacume is clogged, or a compartment that is u\supposed to be sealed is broken, or it has a leak somewhere..
My bet is that it is clogged somewhere, take it apart you will find it..
Jan 09, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner Logo
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
