Question about Honeywell 5816WMWH, Wireless Door/Window Transmitter w/Magnet, White
DOOR/WINDOW SENSOR NOT WORKING
THE SENSOR FELT OFF FROM THE GLASS WHERE IT WAS ATTACHED AND NOW IS NOT COMMUNICATING WITH THE PANEL?
    Problem Solver:
  • 12 Answers
There should be two parts to the sensor. Make sure both are paired up evenly within a inch of distance. A system or panel reset might be necessary.
Posted on Apr 20, 2014
How do i install a manual window regulator in an oldsmobile 2001 alero
Ok let's do this you need to have tool to remove window crank handle then remove door panel look for screws in arm rest then panel should be held on by plastic push pins remove the by prying door panel with screw driver after removal look at crank handle shaft you will find bolts attaching mechanism to door get help from another person to hold the glass after removing bolts you can work the unit to remove glass from the unit then reinstall glass into the unit and put back in reverse order this will take lots of patience but you can do this the glass is in a metal frame with rollers that slide into the mechanical window regulator make sure glass goes back into the window felt track during reinstall hope this helps.
Dec 05, 2014 | 2001 Oldsmobile Alero
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
Sep 02, 2012 | 1997 Dodge Grand Caravan
I need a left front door/window schematic on line for a 99 Dodge Durango. I need to see how to put it together.
Front Door
  1. Remove the door trim panel.
  2. Remove the water dam.
  3. Remove the inner and outer door belt weatherstrips.
  4. Lower the window to the full down position and align the glass regulator arm with the access holes in the inner door panel.
  5. Remove the front glass run channel.
  6. Remove the nuts attaching the glass channel to regulator arm.
  7. Separate the glass and lift it up and out.
  8. Disengage the power window motor wire connector from the door harness, if equipped.
  9. Loosen the bolts in slotted holes attaching regulator to door inner panel.
  10. Remove the bolts attaching window regulator to inner door panel.
  11. Remove the regulator through the access hole in the inner door panel.
  12. Installation is the reverse of removal. Tighten the nuts attaching the glass to the lift plate to 7 ft. lbs. (9 Nm).
Power window regulator mounting—Dakota, Durango
Window regulator removal—Dakota, Durango
Posting more on next post for door panel removal and installation.
Oct 26, 2009 | 1999 Dodge Durango
How get replacement rear vent window into place? its a 1995 maxima passenger side rear vent window.have picked up a new one from salvage and fear if i force it, it may shatter.
The metal glass run between the vent & doorglass has a phillips screw at the top under the door weatherstrip. I usually remove that screw, with the doorglass down & glass run (felt) pulled down at the top just enough to allow the metal part to move as you force the ventglass into place. lube the vent gasket with silicone spray or any good wet lubricant and force the glass in, bottom 1st. If this makes you too anxious, remove the 10 mm attachment that retains the metal glass run at the lower end of the part. To get to it, you will have to remove the door panel. Good luck
Sep 27, 2009 | Nissan Maxima Cars & Trucks
1990 cutlass ceira how do you replace drivers door side mirror
Outside Mirrors REMOVAL & INSTALLATION Standard
  1. Remove the door trim panel and detach the inner panel water deflector. With the glass in the down position, pull out the front portion of the glass run weatherstrip. Fig. 1: Unfasten the attaching nuts from the mirror base studs, then remove the mirror 8c45877.gif
  1. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler, then rotate retainer rearward.
  2. Remove the noise control patch to gain access to the screw at the belt, then remove the screw.
  3. Remove the filler attaching screws at the top front of the window frame, then remove the mirror and filler from the door.
  4. Remove the attaching nuts from the mirror base studs, then remove the mirror. To install:
  5. Be sure that the mirror gasket is aligned.
  6. Replace the mirror and filler on the door. Install the filler attaching screws at the top front of the window frame. Attach the nuts to the mirror studs and tighten.
  7. Install the screw at the belt, then insert the noise control patch.
  8. Insert the retainer, then install the attaching bolts and screws to the front glass run channel lower retainer to filler.
  9. Replace the front portion of the glass run weatherstrip, insert the inner panel water deflector, then reinstall the door trim panel.
Manual Remote
  1. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  2. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  3. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  4. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  5. Remove the filler attaching screws at the top front of the window frame.
  6. Remove the mirror base with mirror and cable assembly from the door.
  7. Remove the mirror to filler attaching nuts and remove the mirror and cable from filler. To install:
  8. Be sure cable is routed around front glass run channel retainer and installed to clip.
  9. Install and connect the cable to the filler.
  10. Attach the filler nuts to the mirror, then tighten to 72 inch lbs. (8 Nm).
  11. Install the mirror base with the mirror and cable assembly to the door.
  12. Insert the filler attaching screws to the top of the window frame, then install the screw to the belt.
  13. Secure the noise control patch.
  14. Attach the bolts and screws to the front of the glass run channel lower retainer and filler.
  15. Install the glass run weatherstrip.
  16. Attach the inner panel water deflector, door trim panel and mirror remote control escutcheon.
Electric Remote
  1. Disconnect the negative battery cable.
  2. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector and the electrical connector for the mirror. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  3. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  4. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  5. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  6. Remove the filler attaching screws at the top front of the window frame.
  7. Remove the mirror base with mirror and electric connector from the door.
  8. Remove the mirror to filler attaching nuts and remove the mirror and electric wire from filler.
  9. To install, reverse Steps 1 through 6. Be sure electric wire is routed around front glass run channel retainer and installed to the clip. Tighten the nuts to 72 inch lbs. (8 Nm).
  10. Connect the negative battery cable, then reset the clock, radio and any other accessories if required.
Aug 25, 2009 | 1990 Oldsmobile Cutlass Ciera
Drivers door window squeeks when it is opened.
before removing anything, try spraying some graphite spray down the side tracks of the door frame where the glass rolls up and down. do not spray the felts that go cross ways
Apr 26, 2009 | 2005 GMC Sierra
Window regulator replacement
Window Regulator, Rear Door, Explorer Removal
  1. Remove the rear door trim panel and watershield. Refer to Section 01-05B .
Trim Panel, Rear Door, Explorer, Hi-Series Four-Door Removal and Installation
  1. Remove the two screws retaining the rear door trim panel (27406) located above the door handle.
  1. Remove trim cup at the door handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator switch plate (14524) , use notch located at lower end of plate using a screwdriver to lift and remove.
  1. Remove window regulator switch plate from rear door trim panel pulling wire harness from rear door trim panel .
  1. From bottom of window regulator switch plate , remove two screws and disconnect connector from window regulator control switch (14529) .
  1. At each plastic clip location, pry the rear door trim panel away from the door inner panel using the door trim panel removing tool from Rotunda Moulding/Trim Kit 107-00401 or equivalent.
  1. Remove panel, lift slightly to remove flange at the top of rear door trim panel from trough in the glass weatherstrip. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the rear door trim panel to the door inner panel, firmly loading clips into slots provided on rear door trim panel .
  1. If equipped with power windows, disconnect the wire from the regulator.
  1. Remove the rear door window glass as described in this section.
  1. Remove the window guide, if equipped, (nuts and washers). Remove guide from door belt opening.
  1. Remove three 1/4-inch rivets attaching motor bracket (electric) to inner panel and two 1/4-inch rivets attaching regulator lower bracket to inner panel. Use drift punch to knock out center pins for each rivet. NOTE: Use care not to enlarge sheet metal holes in the door inner panel when drilling.
  1. Using a 1/4-inch diameter drill, drill out the remainder of the rivet.
  1. Remove two upper regulator attaching nuts.
  1. Remove regulator from the front door (20125) .
Installation
  1. Lubricate regulator mechanism with Multi-Purpose Grease D0AZ-19584-AA or equivalent.
  1. Install regulator into access hole in inner panel.
  1. Position regulator using upper regulator studs and tabs on motor mounting bracket (electric) or cup mounting plate (manual).
  1. Install rivets attaching regulator to door inner panel (1/4-20 x 1/2-inch bolt and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used as alternates).
  1. Install two upper regulator attachment nuts.
  1. Install door glass as outlined under Door Glass Installation.
  1. Adjust glass as outlined under Adjustments .
  1. Reconnect wire to regulator, if equipped.
  1. Check operation of window regulator.
  1. Install door watershield and trim panel. Refer to Section 01-05B .
Apr 11, 2009 | 1994 Ford Explorer Limited
Replace a window regulator in a 1994 ford explorer
wow, a lot of work to do.
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Loose window on 1987 cutlass
replace all the felt liners on the window track ,and the inner ,outer seals at the top of door where the glass comes up thru,but also ck' the window regulator attachment to the glass at bottom...kev-mn.
Dec 10, 2008 | 1987 Oldsmobile Cutlass Supreme
Honeywell 5816WMWH, Wireless Door/Window Transmitter w/Magnet, White Logo
180 people viewed this question
Top Honeywell Home Security Experts
Sean
Jay Finke
Jay Finke
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
