Question about Royal LR14MX 1 Hour Run Time Paper Shredder
Overload light is on - Royal LR14MX 1 Hour Run Time Paper Shredder
What can you advice me to do? i have a UPS SURTD5000XLI, indicating a red Led light, but when i remove it from the AC power source, the Red Led also remove & when i flog it again to the AC Source it...
Is red light on for overload or for battery?
If on overload, try reducing the load on the UPS. If red light on overload persists buy a new UPS (overload fault hard to repair).
Red light on battery - replace the batteries.
Red light on boost or buck, may mean that the nominal voltage of ups and the limits need to be changed/corrected.
Jun 23, 2014 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
WEA18061AU When turning on start light comes on
Could be overloaded. Use less clothes to start. Load sensing will not let an overloaded washer to continue.
Oct 16, 2013 | Bosch Washing Machines
Powertech 500W Inverter ac light off overload light on.
You might want to post this in a different section. This is the computer laptop section.
Aug 18, 2012 | Computers & Internet
I have a Noma Digital Decorating Instant Light Show Timer and I cannot find the instruction sheet on how to use it. It has 19 preprogrammed light shows and the display shows OL and will not let me reset...
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Dec 02, 2011 | Hardware & Accessories
My problem is dash lights come on when i brake lightly battery light flickers car dies all power out no lights nothing then back to normal
Sounds like a short in the brake light circuit that overloads the alternator.
I'd check / replace the bulbs for brake lights.
I had this happen once...
When you brake...your brake lights come on.
BUT, because the bottom of the bulb or bulbs have shorted, this provides a path for your running lights and dashlights to come on as well and the short tends to overload the alternator causing the flickering battery light.
Because the alternator is taking an overload like that...I'd have it and the battery checked for proper performance.
I'll bet the back bulbs or bulb sockets need attention...
Hope this helps...
Aug 13, 2011 | 1995 Mercedes-Benz SL-Class
Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Nov 24, 2009 | Royal Office Equipment & Supplies
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Royal LR14MX 1 Hour Run Time Paper Shredder Logo
50 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
