Question about Galaxy Radios DX-2517 CB Radio
Rci 2980 dead key to high - Galaxy Radios DX-2517 CB Radio
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Should be vr 14 and vr18
Posted on Aug 09, 2014
The receive is down on the rci 2980 very poor.It only receives the people that are close.What might be causing this problem.
bad swr match , bad ground on antenna . If it a used radio it could be a number of things. Take it to a tech and let them straighten it out for you.
Feb 26, 2015 | Radio Communications
How do i go about fixing the receive in the RCI 2980.It has some receive but it is low.What might be causing the problem.
you are not qualified if you have to ask this question. Take it to a tech and let them straighten it out for you.
Rci 2980 no modauliton on am/lsb/usb/fm.but good recived. and good output.on am.
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
Nov 26, 2009 | Radio Communications
The s-meter goes down scale when I am modulating. What causes this? THIS IS ON A RCI 2980 RADIO
the reason i saked is that if you turn the power all the way up it tends to reverse modulate. this happens because the power is using all the transmit voltage for the final and the modulation circuit is trying to use as much as it can so the radio is most likly out of alignment and needs to be realigned. its not that hard if you have the service manual and the correct equipment. i have a factory authorized shop and we do alot of realignments due to the cb shops tweaking the 10 meter radios.
Mar 12, 2009 | Ranger RCI-6900F-150 CB Radio
Need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Feb 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
RCI 2980 power adjust problem
VR16 is not the low power adjustment, it's the CW Tone.
As far as I can tell, there is no low power adjust.
Try a different resistance pot for the RF Power.
Feb 11, 2009 | Galaxy Radios DX-2517 CB Radio
Radio has no modulation
probably a final is out.
Feb 01, 2009 | Radio Communications
Radio Communications Logo
139 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
