Question about Electric Stanley Tre500 Staple Gun / Sharpshooter
Load staples no idea how to put staples in bottom tray
How do i fill the Quill heavy duty stapler model 7-93200
Little clip to the back bottom slides out and the correct staples are laid in to the staple tray, slide the tray back in and you're ready to staple.
Nov 07, 2014 | Tools & Hardware - Others
I have a Fasco F1B7C-16 upholstery stapler that won't shoot. There's no mechanism to push the staples forward -- is that normal? The instructions are completely useless ... Help!
The staples are loaded in from the bottom of the unit.
Pull out the staple tray all the way to the rear then turn the unit upside down and drop the new staples into the grove in the unit.
Push the tray back into the unit and you are ready to go!
Dec 03, 2011 | Fasco Tools & Hardware - Others
How do I add more staples to a Panasonic Electric AS-302N stapler
I have one right here. Push the button in the back (above where the power cord enters the machine.) The tray holding the strips of staples should pop out of the front of the machine. If it doesn't, try grasping under the staple tray and gently pull the tray out while pushing the button in back.
The button is a release button, while the tray is spring loaded to pop out..
Jul 14, 2011 | Tools & Hardware - Others
I inserted staples into stapler cartrdige wrong way for Canon copy machine(imagerunner runner 3245). I figured out how to open it up by unclicking 4 tabs at the bottom. I was able to take out staples and...
This belongs on the lower plate of the cartridge. It hangs down and indicates when the staples are out. Take the cartridge apart again and look at the bottom plate. There should be a slot and another slot perpendicular to the bigger slot. This is where the two tabs of the black piece pivot on. If I remember correctly there is a rectangular shaped part of the arm and I think it faces up. The arm should hang down a little bit. Then put all the parts back together. Load the staples. Good luck.
May 04, 2011 | Canon imageRUNNER 2870 Copier
I have a stanley TR150HL staplegun and am trying to refill it with staples. How do I do this?
If you use the picture that is posted as a reference, the staples are put into the gun by removing the bottom right- hand ( black insert)spring loaded slider. To describe it another way ..... when you hold the stapler in your hand , the staples go in the shoe bottom at the very rear of the gun. This is shown as the black indent at the back and bottom of gun. It is keyed in and is spring loaded ( to feed the staples) so don't be afraid to wiggle until you see how it is kept in the load trough. Good luck....hope this helped.
Apr 12, 2011 | Stanley Proto Stanley TR150HL SharpShooter...
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Feb 08, 2011 | Tools & Hardware - Others
Have a Electric Stapler B8E E66760. Won't kick out to load staples
pretty simple. Take off the plastic cover, at the front where it staples will be a black metal piece on top of the stapling area. That is the front clip release. Release the staple tray like you would normally with the button and also Push the top black piece back to detach it from the staple tray. It should spring out then. Clean around it with alcohol and keep the cover off. Push it back in place, release it a few more times to make sure it works correctly now, then put the screws back in.
Oct 04, 2010 | Office Equipment & Supplies
Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
May 10, 2009 | Tools & Hardware - Others
Powershot pro staple gun
just purchased a Powershot model 5700m. how do you load the staples?
Oct 13, 2008 | Powershot Tool Company Cobra 8000 Forward...
Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
14 people viewed this question
Top Electric Tools & Hardware - Others Experts
eddie_brown
Level 1 Expert
Mike Carew
Jim London
Jim London
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
