Question about Toshiba 61H71 61" Rear Projection Television
Telefunken led 32FHDP model does not turn on, there is a small red flashing light next to the power light that keeps flashing
2 Suggested Answers
pavlicmaster
  • 171 Answers
SOURCE: tv won't turn on
what remote do you have? if you have a little button called "tv" or "tv2" press one of them and then try tu turn on your TV.
Posted on Apr 07, 2010
Tv wont turn on
I have no clue who makes your TV or the model so I can't really help you. Count how many times it flashes and start googling for the answer. Include all the info you can next time.
Dec 29, 2012 | Televison & Video
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    TV turns itself off, then on automaticlly
    The fan should run for a few minutes after shut off to cool the lamp down.
    If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
    Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
    Apr 24, 2012 | Sony KF-42WE620
    Power green light will flash then flash red when first turned on
    Please intimate exact model of your Sony TV to find out reason of no power up.
    Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
    No sound or picture, 2004 pt50dl54j
    remove back panel. blow out all the dust from all the components except the fan on the right.
    Vacuum out all the dust.
    Have you replaced the lamp? that would help too.
    There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
    Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
    I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
    Try this first before condeming the unit.
    1. Turn off the power supply to the Digistat SCR (receiver unit)
    and leave for 5 seconds.
    2. Turn on power to SCR unit and check red light is on.
    3. Press override button No.2 and check the green light comes
    on and boiler fires.
    4. Press & hold down button No.1 (Keep depressed), then
    press No.2 and keep depressed. {The Red LED light will flash
    a couple of times and then it will go out}
    5. Now release both the buttons – {the two LED lights should
    come back on}
    6. Get the Digistat+2RF/+3RF unit and stand two metres away
    from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
    7. Remove the battery cover and fit the batteries.
    8. The Red LED light on the SCR will now flash for approx. 7
    seconds.
    9. This confirms that the radio signal is being sent and
    received.
    10. The Digistat+2RF/+3RF and the SCR are now successfully
    linked by a dedicated RF address.
    Mar 21, 2009 | Water Heaters
    My xbox 360
    Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
    Aug 22, 2008 | Microsoft Xbox 360 Console
    Power up Problem
    my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
    Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
    Kids.
    Dead, led flashing red/green at first, then going to red standby
    Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
    Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
    Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
    Nov 23, 2007 | Toshiba 32A42 32" TV
    Toshiba 61H71 61" Rear Projection Television Logo
    21 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
