Question about APC Back-UPS XS 1500 - UPS - 865 Watt - 1500 VA
F8 - relay weld
Symptom - error F8 then shut down. Error is a relay fault. I figured out how to open the unit and replaced one relay, but guessed wrong. They are hard to unsolder. Which relay usually fails?
LENOX MINI SPLIT HAS A F8 CODE ON THE SCREEN
Cycle the power to the outdoor unit. F8 is a low or high line voltage fault. Not likely a real error if the unit has worked in the past. Possible power surge or something.
Jun 01, 2017 | Heating & Cooling
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
What is a f12 fault
F01 - Short circuit motor triac*
F02 - Motor jammed or fan blocked*
F03 - Front thermistor open/short circuit*
F04 - No pump piloting*
F05 - No feedback from the pump*
F08 - Static heater relay with contact welded closed*
F09 - Eeprom is not programmed or not functioning*
F10 - Common of heater open or one shot open*
F11 - No pump connection*
F12 - Communication error between board*
F13 - Rear thermistor open/short circuit*
F15 - Dynamic heater relay with contact welded closed*
F17 - Master relay welded closed* - See more at: http://www.hotpointservice.ie/help-and-advice/error-codes/#sthash.nR8Jb1cP.dpuf
Dec 12, 2014 | Hotpoint Dryers
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
Whats the error type for the hotpoint cdt40 error code - flashing on/off and flashing 'time delay'. I've got heat, the pump is working, the water resevoir is empty
went to a free forum and the experts there stated it was a code F08 fault and that one of the heater relays was welded open - to identify the correct relay was prohibitively expensive and a specialist card reader was also needed and that it wasn't worth the repair.
Dec 30, 2009 | Hotpoint Dryers
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint CTD85A F15 error not drying clothes
Hi
f15 means heater relay on pcb is welded closed
which basically means the pcb has failed and needs replacing.
regards
Mar 22, 2009 | Hotpoint Dryers
Hotpoint ctd 80
The error code F10 is common of heater open circuit or one shot thermostat open circuit.
F8 is indicating static heater relay contact welded closed.
You need to call an engineer.
Oct 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Jul 15, 2008 | Ovens
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
APC Back-UPS XS 1500 - UPS - 865 Watt - 1500 VA Logo
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
