Malber p21 parts
Good day Gentlemen, The plastic handle of my automatic was machine Malber Model P21 is broken and I need I new spare. Please let me know the fast solution to get it at home.
  • 163 Answers
SOURCE: Malber p21 spin
the lid switch must be broken if you know how to use an screw driver you can fix it remove the lid witch and replace with a new one, remember to unplug the machine frome the wall...good luck
Posted on Aug 06, 2006
SOURCE: washer is jumping extremely only when spinning
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Posted on Apr 01, 2008
SOURCE: Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 washer on board a boat and it will not spin out the water. It is spinning but the water remains in the tub
Posted on Feb 19, 2009
SOURCE: I NEED A NEW HOSE
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Posted on Jun 29, 2009
  • 80 Answers
SOURCE: my malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Posted on Apr 01, 2012
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
Service manual need
I have a malber washing machine and it is broken. One day, a loud noise came from the machine then, the machine would not spin out nor did the water drain from the machine. I would like to find a repair place who could fix my machine. I live in Providence, Rhode Island and would like to locate someone local. Can you please help me?
Apr 26, 2013 | Malber P21 Front Load Washer
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
Thanks
Apr 01, 2012 | Malber P21 Front Load Washer
Broken front door handler,I need door or broken part-opener
its called a screw driver and force what your looking for.then you have to replace wat ever broke.
Jan 11, 2011 | Malber P21 Front Load Washer
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
Jun 25, 2009 | Malber P21 Front Load Washer
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Door handle
Malber...hmmm..sounds like a european make, right? only way to find that is perhaps accessories at website?
Mar 11, 2008 | Malber P21 Front Load Washer
Door handle
I have done this myself, breaking same part and fixing. For parts call 718-767-7396 in NY. I hope they will ship to you if you are not in NY. Good luck!
Jan 16, 2008 | Malber P21 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
