Question about Toshiba 36A50 36" TV
Viore tv remote code ur5u870l - Toshiba 36A50 36" TV
I have a Viore TV and I need the remote tv codes.
Most UPC's do not include the Viore, it is a non standard set. Some codes from others may work it
like 0092 316(tivo)
here is a response from the manufacturer.
Unfortunately, there would not be a remote code for this unit in your existing remote. The code would have to be already manufactured in the the remote that you have. This is a brand new unit from a new factory which has a whole new set of remote control information. We have provided our code information to several companies that maintain universal remote databases. There is a lag period before the remote with the new information can be manufactured and provided to cable TV customers. The only universal remote that would have our remote information readily available is a PC-programmable universal remote that allows the customer to download the code information (not a remote code) from the internet directly to the remote. Thank you for your inquiry.
Viore Technical Support
1-866-278-5900
Plese rate my help++++Thanks for using FIXYA
May 23, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
Need the dish network code to Viore tv
Viore is a generic of Samsung brand TV's. Try using their list of codes, the code for mine was 0085. Hope it helps 8-)
Nov 14, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Viore LC32VH55 HDTV IR code. Is it updated in the URC-4021 controller ? TV uses NEC1- Protocol 96-157. I think the code is an AKAI of 1207. Cn U verify and solution
After A LOT of blog reading and a few tech support calls, I think the only codes are 11207 and 11684 but neither work for my new Viore LC32VH55. I wouldn't have bought it had I known it wasn't compatable with Directv! I can't believe that there's no solution for this... I can't turn the volume up or down without using the tv remote and I'm so frustrated!!! Anyone know if a universal remote will work for both the Directv receiver and this stupid Viore TV?
Don't buy a VIORE! It's an okay tv but not worth the hassle!
Oct 17, 2009 | One For All URC-4021 Remote Control
Remote code
Contact them here:
Parts & Accessories
(remotes, cords, manuals, service parts etc.)
accessories@viore.com
Oct 17, 2009 | Toymax Viore 42 in. Plasma TV
What is the code for cable remote
Viore told me that they do not have a code that can be input into any remote. I have two Viore TV's... just bought my 2nd a few days ago. You will always have to use the Viore remote to power up or just turn off the cable instead. Not sure that turning off cable completely turns off the TV though.
Jul 31, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
Mar 09, 2009 | Toymax Viore 42 in. Plasma TV
Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Feb 16, 2009 | Olevia LT42HVi 42 in. LCD Television
Set up code for viore tv remote.
Did you try conyacting allforone to get the code or an alternate method to enter the code by scanning ?
Dec 30, 2008 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Code for viore tv. 1403 does not work
Have you tried using Akai TV codes.
You could also contact Viore on 866 278 5900 or
Email Technical support. techsupport@viore.com
website www.viore.com
Jul 05, 2008 | Philips PM3S Remote Control
Toshiba 36A50 36" TV Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
