my unit burns only upto 5 or 6 percent. i have waste so many CDRs already. the nero is not the culprit because even on windows media player it does the same. i think, its better to burn this dvd writer and get a much better brand.
Comments:
Jun 19, 2009
- have tried so many cd brands already but to no avail. virus? i have an update version of kaspersky 2009. havent tried lens cleaning yet.
Jun 22, 2009
- thanx basit147, you are right. the only solution is to check first if there is a virus on your system. period. this virus may not bother much on your daily tread but somehow it interferes or worst, it interrupts the burning process.
how i did it frustrated with none working solutions, what i did was to try the last resort (quite unusual), to scan your system for virus. last resort because i relied so much on my installed anti-virus, thinking it is doing its job. no, it doesnt. i tried to switch my anti-virus off and run a trojan remover. this remover did the job. it has removed quite a number of viruses.
after running this remover, i tried burning and was always successful 100%. i now made it a point before burning, to search and delete viruses first before burning.
another solution though is to change the brand of the disc you are using. but in my case, the ones i used is quite okay.
if all elses fail, then, that is the time to burn the burner and look for a better brand.
i actually modified udma in bios from 4 to 6. it is still only 4 the maximum the drie supports, but the bandwidth that the chipset reserve for the dvdrw feeds it better. gsa-h54n does not support any of my ricohjpn w11 media (dvd+rw) although the code is in the firmware accepted media.
Udio and other av cds are working. But when i inser dvd it not neither reading nor opening. msg...
(More)
Udio and other av cds are working. But when i inser dvd it not neither reading nor opening. msg inser cd is also not displayed Kindly advice
My computer's dvd rom is causing problems. When I disconnect my dvd rom , the computer won't boot...
(More)
My computer's dvd rom is causing problems. When I disconnect my dvd rom , the computer won't boot past the hardware test for the bios. Have it set up with a IDE hdd , with the hard drive as master and the dvd as slave. When I replace the dvd rom with a old cd rom , it works fine, but when it's only the hard drive connected , it won't start.
I just copied a disk,inserted a blank and the unit shut off.Checked all power connections.Manually...
(More)
I just copied a disk,inserted a blank and the unit shut off.Checked all power connections.Manually removed blank media. Tried reboot.Still no power.Could the power supply have just puked?
vista basic on Fujitsu Siemens laptop gsa-dvdram t40n reads cd and dvd but will not write dvds , i...
(More)
vista basic on Fujitsu Siemens laptop gsa-dvdram t40n reads cd and dvd but will not write dvds , i know it was ok a month ago. Can anyone help or provide a help linkas i have tried FS help desk and downloads and a clean set of windows installed Thanks
