Question about Samsung SCX 4521F All-In-One Laser Printer
When i turn on my printer theres a message appear toner low
I change a toner because the first toner i put was getting low, thats why i replace new toner. but when i replaced it, an error comes out says " toner low " is there any reset of this?
    Sergeant:
  • 361 Answers
In your cartage have green cheap or fuse these are reseter. the are aviable in market .change it . then your printer can work. when are u getting tonner low. recently u shuld fill cartage. i think you get empty message. just reseting cartage by new reseter than u can change old reseter. u can 100% solve your problem thanks
Posted on Jun 19, 2009
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
Hi, just replaced my toner on the MFC-7220 and a message Toner Life End is displayed and will not print. I have tried 2 brand new toner cartridges. Thanks, Linda
Hi there !
Try this solution if it works, the memory of your printer still programs that your toner is end.
Try to make hard reset of your printer by turning off your printer for 5-10 mins, unplug the power cord as well and remove the cartridge toner. Then return back the cartridge, plug the power cord and then restart your printer. Then try to print again.
If displaying still this message, just press stop button to remove the message.
Also, if there is wiper for cleaning the toner cartridge everytime your put new toner, please do it.
This is what we do in your bother MFC printer when this message appears. Just restart the printer and keep pressing stop button when the printer starts.
I hope it helps you. Regards.
Jan 31, 2011 | Brother MFC-7220 All-In-One Laser Printer
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears. Have turned...
Nice job on trying different ways to resolve the problem - turning off/on the printer, removing power source, reseating the cartridges and even changing the cartridge with a genuine Lexmark cartridge. You pretty much did the necessary. Genuine Lexmark cartridges shouldn't cause you that much trouble. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Sep 01, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Minolta 2300DL Magicolor printer
EAch cartridge has a small ( about 1/4 inch square) stainless steel color metal tab at the end of the cartridge opposite the refill cap end. The surface of this little tab is visible when the cartridge is "low" on toner and this causes the machine to give the message to change the cartridge. As the cartridge gets older I've noticed that this tab moves to the exposed position more readily, which causes the message to appear. If you google how to reset the position of this tab, then the message will not appear. EVerytime I refill the toner of a cartridge I check to make sure to reset the position of this little metal tab.
It is difficult to describe how to reset the position of the tab. You have to stick a small regular screw driver into the slot below where the metal tab appears and find the lever which can be pushed to reset the position of the tab. You can likely find photos of this procedure on google.
Feb 22, 2008 | Konica Minolta magicolor 2300DL Laser...
How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Jan 13, 2008 | Konica Minolta magicolor 2430 DL Laser...
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Samsung SCX 4521F All-In-One Laser Printer Logo
416 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
