Question about Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive
How do i use the hard drive to save too - Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive
Hi, For a week or two now when i put my Sony Vaio on i get a message saying my hard disk is failing & to back up my files but when i put a disk in it fails to back up. It's also telling me the name...
You need to purchase a new hard drive and have it installed, If you have anything important on your laptop right now, that is what you want to create a backup of, or you can have the store you buy the hard drive from do the back up for you and most computer stores will load it all to the new drive for free
Aug 22, 2011 | Computers & Internet
I have an WD1600 and Windows don't want to startup. It Always restart. I've tried to repair windows with CHKDSK, but i have bad sectors that can't be repaired by CHKDSK. I can't find any...
Mohamed if the hard drive has bad sectors on it is best to replace the hard drive itself. But you need to save the files first by doing so, you have to do a parallel re install. Parallel re install is like booting your hard drive with 2 operating systems for details on how to do that click on this link.
Once you are finished try downloading and saving it on a external hard drive all the files that you saved. Purchase another hard drive and upload the files that you have saved
Jul 18, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
I cant save anything on the 1T external hard drive. I am running windows 7. The computer reconizes it but wont save
The Hard Drive must be Write protected. There might be a Toggle switch around External Drive for Write Protection. Or can you save files to any other USB Drive (Pen Drive) ?
May 18, 2011 | Samsung G3 Station 1TB USB 2.0 Black...
I cant seem to use my 320 gb mobile hard drive. when i connect it to the usb, my laptop reads it but i cant save files into it..help me please.
try to connect your device into your pc and then, try to save files again, if this doesnt work, try to reformat your hard drive, im sorry to say that all your previous files will be deleted upon the format. after this, make partitions to hard drive. then save some of your files into it. if that doesn't work either, try a disk scan to check if your hard drive has bad sectors.
Nov 01, 2010 | Western Digital Elements powered by WD 320...
Putting old hard drive in new ps3 to get game saves error
You cannot switch a hard drive from an old ps3 and put it into the new one. The new ps3 will know that a new hard drive was inserted and offer to format it.
To get the games off the old hard drive, put it back into the old ps3. Insert a USB flash drive into a USB port on the PS3 and you should be able to copy saved games from the hard drive onto the USB flash drive. You can then plug the USB flash drive into your new ps3 and copy off the saved game info,
Mar 17, 2010 | Sony PlayStation® 3 (80GB) Console
Trouble Saving to my Iomega External Hard Drive
Some versions of xp like to set permissions excessively, check security settings
Mar 14, 2010 | Computers & Internet
I accidently deleted everything on my hard drive, what can I do? How do I recover it?
im sorry to tell you this but you cannot retrieve deleted content on your hard drive unless you saved it on a memory card or another hard drive if you did put the memory card in slot a and transfer it on your hard drive or if you saved it on another hard drive replace your current hard drive with the one with saved data on it.
Dec 23, 2009 | Microsoft Xbox 360 Console
How do i save something to my 4GB cruzer HARD DRIVE
Assuming you have the drive hooked up to your PC, you should be able to open the drive using My Computer. You can simply open the folder and drag and drop any files you wish to save onto your SanDisk drive.
Dec 12, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Save/load problem on ps3
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 13, 2009 | Sony PlayStation 3 40GB System
Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive Logo
21 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
