Question about Acer Aspire L100 PC Desktop
Time adjustment my computer clock is at 01 31 instead of 0930
  • 244 Answers
Re: time adjustment
Change the time using your CMOS setup
Please rate me solved if you like my solution.
Best regards,
Posted on Nov 02, 2007
0 characters
3 Points
Clock not keeping time
Log onto your Computer and adjust it by Adding the Correct Time zone
Oct 10, 2013 | Dell Vostro PC Desktops
My computer clock has the wrong time
right click on the time & look for--adjust date & time--& adjust to the right time you need & also the time zone
Sep 15, 2011 | PC Desktops
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | PC Desktops
How do I set my clock on my computer? It says that the time is 6:45PM when it is actually 9:36PM eastern stander time..
double click the clock/time in the system tray in the lower right of your computer screen, then click on the time zone tab and select the eastern standard time zone and tick off the box in the lower left of that box for the automatically adjust for daylight saving time, then select apply in the bottom then recheck your should now read the correct time.
Jul 16, 2010 | Dell Dimension 3100 PC Desktop
How do you update the time when changing to daylight savings time?
There is option in date and time settings. On the right side corner of your screen where date and time are displayed. Doubleclick to open
Click on Time Zone Tab and select your time zone and tick the option "Automatically adjust clock for daylight saving change"
Like the one in link
Hope this helps
May 16, 2010 | PC Desktops
How to set the clock on my computer
Double click the clock down in the right lower corner click the middle tab and select your correct time zone. The computer should set the time automatically from here on out
Apr 05, 2010 | Dell Inspiron 530s Desktop Computer...
Connect my camcorder to my computer.
TDK -ZCAT2035-0930 AVR/VIDEO to USB cable
Nov 09, 2009 | Dell PC Desktops
I just set up my everex gpc. The desktop clock says 8:34 am; it's 4:25 pm here and I can't figure out how to adjust the clock. Also, how do I set up an additional account with seperate login password?
Try right clicking the current clock a context menu should appear and near the top you should see "Adjust Date/Time" clicm on it and a new window hould appear and allow you to adjust accoringly. To add a new user go to the control panel and click "User Accounts" and navigate accordingly.
Hope this helps!
Apr 23, 2008 | PC Desktops
Clock will not adjust properly
Inside the PC is a small lithium cell battery that may be going bad. Or, check for updates on microsoft update to get the clock settings where they need to be. Also check in your settings that you are set to the correct time zone.
Apr 07, 2008 | HP Compaq Presario S3040SE (DF222AR#ABA)...
Computer clock
Right click on the time on your taskbar. Click on on adjust date/time. Then just pick your month, day, etc. Hope this helps.
Mar 31, 2008 | Gateway GT4022 PC Desktop
Acer Aspire L100 PC Desktop Logo
75 people viewed this question
Top Acer PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you an Acer PC Desktop Expert? Answer questions, earn points and help others
