Question about Pentax Optio S50 Digital Camera
Pentax OptioS5Z, battery won't stay in, springloaded 'fastener'
Stopped working properly. Unless the battery is held firmly, the camera won't work. Is there any easy method of reviving the little orange springloaded part that holds the battery in place please?
    Sergeant:
  • 321 Answers
Only tape it otherwise change the body cover
Posted on Jun 19, 2009
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
Hi , I have a Pentax optio S10 the auto focus has stopped working , sometimes I have a yellow triangle with " ! " and a hand signalling stop , any ideas please ? thanks
remove the batteries first'
pull the memory stick put it back in
put good (proper milliAmpere hours) new batteries in the camera
If that does not work \turn off the camera
remove the memory stick
Repeat power up
Aug 19, 2010 | Pentax Optio S10 Digital Camera
Pentax mx won't stay on. As soon as I turn it on the camera turns its self off. Before it does that you hear a clicking sound.
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 15, 2009 | Pentax Optio MX4 Digital Camera
Lens keeps movin in and out (Pentax M20)
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Pentax Optio M20 Digital Camera
PENTAX K1000 CAMERA EXPOSURE METER IS NOT WORKING
Clean the battery cap and contacts with a pencil eraser including the cap threads.
there are no new parts available for this model Pentax, so a good used part repair could be expensive.
An inexpensive hand held light meter might be the way to go if the cleaning did not work, and the camera is otherwise working good.
Nov 05, 2009 | Pentax Photography
Exposure needle not working
clean the battery cover and contact with a pencil eraser making sure the cap threads are also clean.
this is a fairly expensive repair if the meter or circuit board needs replacing ( no new parts are available ).
if the meter still does not work, and the K1000 is in good working order buy a inexpensive hand held light meter.
Jun 11, 2009 | Pentax K1000 35mm SLR Camera
Pentax Optio S50 Digital Camera Logo
94 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
