Question about HP DeskJet F380 All-In-One Printer
Reset hp f380 counter - HP DeskJet F380 All-In-One Printer
I have a HP F380 All in One Deskjet Printer Mac OS 10.5.8 Printing for over 2 years using Airport Scanning I need to connect by usb Issue: I reset the settings and can't find the driver I used to...
Thanks for using Fixya.
First, Uninstall your HP F380 and then again reinstall it.
If your printer is connected via usb to airport extreme you will have to download and install the following.
1. espgs-7.07.1.ppc.dmg
2. hpijs-foomatic-2.0.2.ppc.dmg
Do this by going to The Linux Foundation (http://www.linux-foundation.org/en/OpenPrinting/MacOSX/hpijs)
Install in the order listed above, they both must be installed for this to work.
Then do the following:
1. Go to > system preferences > print & fax
2. Click "+" to add a printer
3. The HP F380 will be listed with the connection type "Bonjour"
4. Highlight this printer
5. At the bottom of the window you will see the option for "Print Using" and than you can choose something from the drop down menu.
6. Scroll down to "HP" and choose that
7. This now propagates a window full of HP printers including the HP F380 drivers that you installed above.
8. Scroll down until you see "HP F380 FOOTMATIC" and highlight this.
9. Click "add".
That's it, your done and it should work.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Mar 18, 2010 | Office Equipment & Supplies
I have an hp deskjey f380 printer and i lost my
CLICK HERE select operating system the download software and drivers :)
Jan 22, 2010 | HP DeskJet F380 All-In-One Printer
Computer don't find HP Deskjet F380. He finds
Download & Install the drivers from the vendor website.
Revert back for more assistance.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Problem on HP F380 all-in-one printer
printer hardware problem.........im sorry to tell you your printer has ink spilled inside it due to overheating /wrong papers used/ something fiddled with the printer .etc.
call hp up aat 18004746836 and ask them for an upgrade printer with 50-60% discount
May 29, 2009 | HP DeskJet F380 All-In-One Printer
Hp 818 print cartridge show incompatible after refill, or show problem with print cartidge. how to use them after refill without any problem
Whoever is doing refill for you should know that HP cartridges have electronic sensors that measure level of ink. They should have procedure with which they either reset the counter or "fool" the cartridge to work after refill.
Basically, you can't do anything yourself.
May 03, 2009 | HP DeskJet F380 All-In-One Printer
My epson RX590 WasteFull ink
The RX590 adjustment utility is available if you look here:
http://www.servicemanuals.ru/download/epson/adj/590ap.rar
(CHECK IT FOR VIRUS OR MALWARE INFECTION BEFORE YOU USE IT!)
If you just want to reset the waste ink (protection) counter though I would recommend that you use the IPR_A10 utility that Epson have released in the USA...
More information is available here:
http://www.wasteink.co.uk/category/ipr/
Mar 21, 2009 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
