Question about iPhone Apps
I cannot get into my utility accounts - iPhone Apps
How to Make a Admin Account on OS X?
  1. From the Apple menu choose System Preferences.
  2. From the View menu choose Accounts.
  3. Click on the lock and authenticate with an administrator account.
  4. Click Login Options.
  5. Click the Edit button or Join button.
  6. Click the Open Directory Utility button.
  7. Click the lock in the Directory Utility window.
Oct 20, 2016 | Computers & Internet
Hacck instagram account
try this +1-855-770-7790 they help me
Feb 20, 2015 | Facebook Instagram
I want to knowif i can access mychecking account on line
If you suspect that there is something wrong with your operating system, you can test and fix it using Norton Utility (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Mar 09, 2014 | Computers & Internet
Can't creat new account with yahoo
Probably there is Yahoo cookies in your laptop and it prevents you to create a new account. Clean up your software using this Norton Utility first before attempt to create a new Yahoo account.
Mar 02, 2014 | Computers & Internet
Create system suite account
When you insert the 1st CD it should start up the install process and ask you for your Registration ID. Just enter that and it will proceed.
Jan 01, 2014 | Avanquest Software FixIt Utilities...
I deleted users, is there any way to get them back?
If by users you mean the local PS3 accounts, they can be recovered only if you've backed them up previously. Just insert whatever media you backed your system up on (DVD, hard drive, flash drive, etc) and use the Backup Utility to restore it. The Backup Utility can be found if you navigate to XMB > Settings > System Settings > Backup Utility.
If by users you mean Playstation Network accounts, you can "re-link" a local PS3 account to a PSN account. Once you've made a local account and have logged into it, go to sign into the PSN and enter your PSN information. Select the option to remember the information and the accounts will be "linked."
If by users you mean PSN friends/buddies, you can just re-add them assuming you remember their PSN names.
Hope that helped!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
Find norton product key
If you already installed the Norton program you can find the product key from Symantec folder located in my documents
or you can find out from your Norton account
to access Norton account go to www.mynortonaccount.com
Jul 01, 2010 | Symantec Norton AntiVirus 2010 / Norton...
I am unable to log in in my pc due to password forgotten and i don't want format the window because a very important data is there.would you like to give me an appropriate way.
There is a utility you can get off the internet called Sala Password renew. Add this utility to a bootable disk, boot your computer to that disk and run the sala utility. It allows you to change the password to any user account that you remember the name of. Generally, it is best to change "Administrator", from that account you can change the other user accounts.
May 11, 2009 | HP Computers & Internet
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Apr 23, 2009 | Minolta Office Equipment & Supplies
iPhone Apps Logo
67 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
