Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
My DCS401-16 starts w/difficulty, but won't run long, is leaking.
My Makita worked well until recently, except for fuel leaking and bar oil continuing to seep after shut-off. Now won't run after difficult start. Most recently, will not start at all and fuel leak worse, at top of tank where lines penetrate.
  • Emmet Myers
    Emmet Myers May 11, 2010
    you will need to find out where the fuel is leaking from? is it eh talk or the line or maybe the carb?
  • John Bossolt
    John Bossolt Sep 24, 2012
    Fixed - tear in fuel line, a frequent phenomenon. Stock up on these.
    President:
  • 2,220 Answers
I suspect you have cracked fuel lines. An open line causes the saw to run lean. To large a leak and she won't run at all. Check your area for a Dolmar (owned by Makita) dealer. They sell red versions of your blue saw and for a nominal fee will be happy to help.
Lou
You own a pretty good saw.
Posted on Sep 04, 2009
Testimonial: "Great saw, but fuel flex line is prone to failure."
  • dontbother10
    dontbother10 Sep 04, 2009
    Running it lean can damage the piston and cylinder. Please get it repaired.
Trouble starting chain saw
check for spark and install new spark plug take off air filter check for fuel
Feb 12, 2015 | Makita DCS6421 64cc Chainsaw with 20" Bar...
My 1985 Skyhawk won't start. Cranks well but no start
BAD COIL OR IGNITION MODULE INSIDE DISTRIBUTOR RUN OHM TESTS TO VERIFY
Dec 08, 2012 | 1985 Buick Skyhawk
Makita dpc7311 leaks at crank
The DPC7311 is a two-stroke demolition saw, there should be no standing fluids, oil or otherwise in the crank case to leak out. The reason it uses a 50-to-1 gas-to-oil mix is so the oil in the gas can settle on the moving parts and lubricate them.
If you do have anything leaking anywhere out of your crankcase you most likely have problems with your carburator in that too much fuel is getting into and filling up the crankcase.
You should also look to make sure your leak isn't coming from a crack in the fuel tank or from the carburator or fuel line and running down to look like it's coming from the crankcase.
Feb 06, 2012 | Makita Saws
XL UT # 10655A Serial # HL1490086 XL 2 Serial # 40152376 Recently bought these 2 saws and have gotten 3 answers for the gas/oil mix. Can you tell me what is the right mix??
Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 18, 2010 | Homelite Garden
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Jul 12, 2010 | Makita DCS640120 Commercial Grade 20Inch...
I have a Makita chainsaw and have forgotten what kind of oil it takes
Use regular bar and chain oil for the oil tank. Use modern synthetic saw oil for the fuel mix. Both are available from home centers, hardware stores, and saw dealers. Be sure to premix the fuel and oil in it's own can and agitate thoroughly before refueling the saw. Hope this helps!
Jun 09, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
What ratio oil to use dpc7310 73cc 12power
Page 12 - 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Your OM
http://www.makita.ca/data/upload/tools/DPC6410,%20DPC6411,%20DPC7310,%20DPC7311,%20DPC7320,%20DPC7321,%20DPC8112%20-%20ENG%20&%20FR_owner_English.pdf
It will operate on 40:1, but starting is more difficult and it carbon fouls much quicker. Failure is usually caused by an undetected air leak the additional oil will not preclude it.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Makita DPC7310 73cc 12" Power Cutter
Brand new Makita MAC2400 is leaking oil.
Send it back Right now do not keep iT NO IT SHOULD NOT BE LEAKING LIKE THAT Paul
Jul 03, 2009 | Makita MAC2400 Electric Powered Air...
Makita dcs 34 oil not getting to chain bar
Clarification Request
Posted by rowdy45176 on Feb 21, 2009
What I would do first is remove the bar and run the saw a short time to see if oil coming out of pump (make sure there is oil in the tank) if so recheck the bar for blockage in the small round hole in the side and run something like a paper clip or small piece of metal to clean out the groove. If you need a breakdown for this tool you might want to try Makitatools.com. I haven't checked to see if it is there but usually it would be. Good luck
We need Make, model and serial numbers from the manufacturer's tag to help you any more. Your manuals can be found here:
Dolmar/Makita
http://www.makita.ca/index2.php?event=toollist&categoryid=7
GL
Lou
Feb 21, 2009 | Makita Garden
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
350 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Tim Venetis
Are you a Makita Garden Expert? Answer questions, earn points and help others
