Question about Magnavox MDR513H/F7 Player
Mdr513h remote remote stopped working
My remote start quit working all of a sudden. The lights and everything comes on like its supposed to but it doesn't start. The remote still locks and unlocks
My Remote Car Starter Stopped Working! - DON'T PANIC!
www.mobileedgeonline.com > Remote Car Starters
This time of the year rarely a week goes by that we don't get a call from someone stating that their remote car starter stopped working. Nearly every call is the ...
So Your Remote Starter Stopped Working.... Just Relax!
www.wssdriveeasy.com/remote-starter-stopped-working/
Sep 29, 2013 - You press the button on a cold Winter day to find that your remote starter stopped working! Take a deep breath. It is probably something very ...
My remote starter is not working, how do I fix this? - Compustar
https://support.compustar.com/.../202533874-My-remote-starter-is-not-w...
When your vehicle's remote start stops functioning the solution can change depending on each situation. The Compustar remote will not...
Remote Starter Won't Start - YouTube
? 1:02
https://www.youtube.com/watch?v=EuHu2VFx0ks
Nov 4, 2012 - Uploaded by daniluchison
Remote controls sends signal to Remote Starter but after a few 'clicks' it won't start the ... 04-08 Pontiac ...
remote start problems - YouTube
Jan 14, 2016 | Cars & Trucks
The power supply has a problem.... secodary has no power??? do you think the transformer is the problem?
It may be that or the supply is not being turned on internally--considering schematics usually do not exist for this kind of equipment unless this is an expensive unit it is usually better just to buy a new one.
May 18, 2012 | Magnavox MDR513H/F7 Player
Dvd disc incompability
Then just use +r or +/- r. You DVD player is not compatible with +r
Jan 13, 2012 | Magnavox MDR513H/F7 Player
I have a Magnavox h2160m9a hdd&dvd player /recorder with digital tuner,the next button used to advanced at 10 minute intervals,now it advances an hour.Can i rest it or send it back to the factory for...
No,it is not necessary to return it..
As far as I explore it ,this feature is user adjustable ..Have you gone thru "user manual " ?
if you need a soft User Manual in PdF format I have a copy of " "..H2160MW9 HDD & DVD PLAYER / RECORDER WITH DIGITAL TUNER " *another version of yours..
if you like I can forward to you too..just give me your e mail..thats it..
Take care..Regards
Jul 29, 2011 | Magnavox MDR513H/F7 Player
3 month old magnavox mdr515h/f7 is dead. It may be under some warr. Had power go off during a storm last night. Unit was plugged into a surge strip and other items on it are ok. don't know if it quit then...
My unit was dead also.....So I checked outlet first...It was good....Then I tried the 10 minute disconnect and reconnected unit......Saw Unit had power on LCD screen....Hit ON button on remote after changing to HDD and unit works perfectly again....That fix saved me 75 bucks for repair center to do same thing...Glad Funai makes units that shut off before damage occurs...Unit just needed to cool down hard drive or circuitry before it sensed it was ok again....When plugged in it is still technically powered even tho you dont see it on the LCD screen of the unit...
Mar 21, 2011 | Magnavox MDR513H/F7 Player
Power supply different voltage supply will it work in Australia
Unless the power supply is a multi-system* type, the unit will not work in Australia without major modifications to suit the mains voltage. The differences between USA and Australian voltages are significant. We use a higher voltage rating for appliances than America does, and appliances made for Australia operate at around 220-250V AC.
In order for it to function correctly and safely in Australia, the power supply would need major modification, which can prove expensive, and often impractical.
Mar 02, 2011 | Magnavox MDR513H/F7 Player
I purchased a MDR513h/f7 hdd & dvd Player/recorder for my cable TV. I can not watch one channel while recording another. Comast said I must have a dual turner and that is what I purchased (I think)....
This model has only one tuner, I'm afraid. You can only watch one channel at a time, unless you split the cable signal going into it. One side goes to the recorder, the other to the TV. Then you use the single tuner in the recorder to record and the TV's tuner to watch the other channel.
Sep 12, 2010 | Philips Magnavox DVD/VCR Dual Player
Open Questions:
See all Magnavox MDR513H/F7 Player Questions
Magnavox MDR513H/F7 Player Logo
24 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
