Question about Sansui VRDVD5000 DVD Recorder/VCR
Where to replace burnt out PCB.
Hi, I'm trying to locate replacement PCB's for a Sansui DVD recorder. It appears as though I suffered a power surge and have had several components (capacitors mainly) of the power supply PCB cooked. I guess that all brands basically have generic type boards but I am unable to locate any distributor.
Thanks darryl
Unfortunatly I have the same problem but it seems the main MOSFET bolted to the heatsink (SSS4N60B) in the high voltage section has failed which I suspect has led to the destruction of the capacitors. I lost the 5v and 12v supply which happen to have the damaged caps in there circuit. See how you go but I'd be having a close look at that MOSFET as well.
Posted on Aug 29, 2009
  • 37 Answers
Ok if you check the board-boards and replace all
the caps that have vented (expanded) with new ones. you may be in good shape then!
Posted on Jun 19, 2009
My Toshiba DR430KU dvd recorder is not recording. I hit the record button, and the light comes on, saying that it is recording, but nothing gets recorded.
Hello
Secure the audio/video connection cables that attach the source device you are trying to record from. Try this step if you do not see a picture when trying to record from a source device onto the Device. After unplugging the cable and checking for any damage, plug the cables back and attempt to record the content to see if this resolved the problem.
Secure the power cable that attaches the device to an electrical source if the unit will not power on or if it intermittently loses power. If you think a malfunctioning surge protector may be at fault, you can 'bypass' the surge protector by plugging the device into an electrical outlet. Replace any surge protectors that appear to be malfunctioning and have an electrician examine any outlets that appear to be "dead."
Insert the disc that you would like to record
Press the "Edit Menu" button on the remote control while playing the disc or while playback is stopped.
Use the up and down arrows to select "DVD-Video Finalizing" in the on-screen menu, then press "Enter."
Under "Menu Create" select "None," then under "After play final title" select "Stop." Select "Next" to move to the next screen.
Select "Writing" in the lower right of the screen.
Select "Yes" or "No" to tell the machine if you want it to power down when finalizing is complete. Finalizing will then begin and a progress bar will appear.
Contact your electronics dealer or the Toshiba service department if the disc still does not finalize.
Apr 19, 2011 | Toshiba DR-430 DVD Recorder
My Panasonic DVD recorder won't turn on after a power out. Another user says that this is common, it may be a burnt diode or a damaged power supply. WOULD TURNING THE POWER STRIP OFF RIGHT AFTER THE POWER...
If the power supply has already suffered the brunt of the surge, it could be an expensive repair, possibly not economical.
Of course, you can submit this recorder to a service centre, and obtain a quote on any repairs/board replacement required, then make a decision afterwards on that basis - yes or no - it's up to you what you do.
Sorry to say the power surge has quite likely destroyed several components in your DVD recorder's PSU beyond economical repair; it would not just be a 'burnt diode'.
However, in the future, if you are worried about likely surges occurring again, you can always switch units off at the power point when you aren't using them (example, overnight when you go to bed or when you go out for more than an hour at a time). This may help prevent expensive damage to other appliances.
Surge protection on your household power (or a surge protected powerboard/strip if that's cheaper and easier to get) is recommended.
Mar 02, 2011 | Panasonic DMR-ES10 DVD Recorder
I have a Sansui DVD + RW Recorder Model No - SAN028-250GB. Would you tell me if its worth me having it repaired, there was a power surge and a bit of sparks and smoke from the rear of the DVD where the...
Hi my name is John. Welcome to FixYa. I believe it would be worth Fixing, Have someone take it apart for you. Probably a diode and a few capacitores, easy fix. Thanks for choosing FixYa....John
Dec 01, 2010 | Sansui Televison & Video
Wont power up, after we had a power surge. It was connected to power strip surge protector, but has not been able to power up since. can it be a fuse problem, or more? magnavox dvd recorder mwr10d6
Apower surge can travel quicker than a surge protector can activate. And a replacement fuse may not fix your DVD. On one occasion I did replace a fuse in one of these after a power surge and the DVD/VCR did comeback to life. You may try...but the odds are against you and you will have to purchase a new one!
Jan 24, 2010 | Philips Magnavox MWR10D6 DVD Recorder
Unit will not record on blank DVD-Rs. No problems until recently. Cannot set up or finalize DVDs after recording efforts.When I click on VIDEO (vs. VR) Unit will not change over for formatting.
There are a lot of similar complaints about your unit, which gets only 3 out of 5 stars on some review sites
and though it says sansui you should not confuse it with the brand known in the seventies as a quality
line, as it is a sub-brand of Orion, now. The unit employs an ide computer type dvd recorder which can
be replaced if you know what your are doing, to minimize your costs, since similar complaints arise after
only three years of use with this unit, and that method of resolution has been tried and succeeded.
Apr 11, 2009 | Sansui VRDVD4005 DVD Player/VCR
Dvd player/recorder wont work
I had the same problem with my sansui san0218-160 dvd recorder, i found a capacitor had failed on the power supply board, i replaced the capacitor and it now works perfectly.
Feb 20, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Buzzing on DVD recorder when recording
The buzzing sound were feed back from power supply regulator if you can replace all of electrolytics capacitor in power supply block you will fix this problem or replace complet PCB
I need the correct model of your JVC DVD recorder
Dec 07, 2008 | Televison & Video
Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Nov 11, 2008 | Smeg WD16BA Front Load Washer / Dryer
Sansui San0218-250GB.
i had the same problem with my sansui san0218-160 dvd recorder. i found the power supply board inside the case had failed, so i replaced two faulty capacitors on the power supply board and reassembled the recorder, it`s working like new again. hope this may be of some help.
Mar 30, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
No Power at all. Fuse T2AL is blown up
Thanks to Bogbrush (what a name!) above for the hint to check R5107 when the STRG6653 explodes, indeed it was open circuit. I replaced that with a non-SM component since that's what I had to hand, replaced the fuse (2AT), replaced the STRG6653 and replaced the mains rectifier since this looked to have suffered even though cold checks implied it was OK. Then rewarded with a fully working DR-MH200. I had already gone through the power supply replacing any capacitors which had gone high E.S.R, several had. The 27uF 35V capacitor in the primary circuit of most JVC DVD recorders is particularly prone to failure.
Mar 04, 2007 | JVC DRMH20 DVD Recorder
Sansui VRDVD5000 DVD Recorder/VCR Logo
156 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
