Question about Velbon VideoMate Deluxe Heavy-Duty Photographic/Video Tripod 607 w/ FREE UPS
Luid Leaks The fluid leaks at the botton of the head, and is very sticky, any solutions
Leaking power steering luid
You need to find out where its leaking from, gravity is usually a good place to start trace the fluid to the topmost wet part. There is usually the leak. I just changed the high pressure line between pump and rack on my 2001 sonata, wasnt terribly difficult but not much room to work on the rack side. The line ran me $65.
Jul 13, 2014 | 2001 Hyundai Elantra
Power steering leaks
Its best not too.just get under car and check the rack and pinion for leaks, and all hoses from pump down, good-day!
Apr 14, 2014 | 2001 Jeep Grand Cherokee
My black&decker electromate 400 compressor runs but will not build pressure
There is an air leak in the system. check the easy stuff first. let the compressor run, and carefully feel around the ends of the tube that runs from the compressor cylinder head to the tank. You can sometimes feel where the air is escaping. You can also squirt a soapy solution on the ends of the tube and look for bubbles or pressurized air blowing the fluid back in your face :-).
When you find the leak, you will know how to stop it. Also check the drain valve at the bottom of the tank to make sure that it is closed and not leaking. Check your hose connections for leaks... remove the air hose and run the compressor.. if it builds pressure, your hose connections are leaking. The harder stuff... Take the shroud off, check the head bolts for torque and the head gasket to see if it is blown, (Use the soap solution). The really hard stuff... If you have found no leaks, the valve body or piston ring(s) are the problem. You'll need to pull the cylinder head and replace the valve body or piston or piston rings.
Good luck
Sep 14, 2013 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Leaking fluid coolant
have a cooling system pressure test done to check for external leaks. have a compression test done to check for head gasket or cracked head. Check under water pump for leaks.
Aug 31, 2013 | 1997 Hyundai Accent
Hi Peter, the transmission runs fine as long as it has fluid but leaks out from the bottom not sure if it is the pan. I saw two holes possible in the pan. 2003 Chrysler Voyager. Is there a pump in the...
The pump is inside
Sounds like you need to get a used transmission
pan for the bottom if it is dented,leaks etc
If your loosing fluid & drive it you will ruin it in
a very few miles when it leaks out
The gaskets are on the botton oil pan,the side drive axle
seals on the case & the front pump seal you can'r see,for
that the transaxle has to come out
Aug 28, 2013 | 2003 Chrysler Voyager
2002 duramax tranny fluid disappearing
your trans fluid is cooled in the radiator , so there is likely a cracked coolant line in the radiator and the fluid is being dispersed as overflow from the radiator
Apr 13, 2013 | GMC Sierra Cars & Trucks
1998 olds intrigue keeps running out of radiator fluid and hoses good
Is fluid leaking onto the ground? Onto the front floor? . If you cannot find an obvious leak, you may want to check you oil when car is cold. Look for traces of white goop, or water in the oil. Smell dipstick and see if it smells like gas . I'm leaning towadrs a head gasket if you cannot find a leak. More details will be needed to say anymore. Have a look for leaks first
Jan 13, 2013 | 1998 Oldsmobile Intrigue
Transmission fluid leaking from bottom of transmission/not transmission pan steady drip!
It is NOT the transmission pan gasket or bolts ?
You have 2 trany line coolers, 1 fill tube, and the tailshaft seal, all could be culprits.
I would say clean the botton of the trany pan off completely, and see if it leaks WITHOUT the truck running.
Then start the truck and see if it leaks, if not, then put it in drive, and see if it is leaking.
Please let me know so I may help you further.
Feb 09, 2010 | 2006 GMC Sierra
Small bubbles in radiator and luid loss not in oil not fouling plugs just looses fluid where ?
It burning it ,you can check this with a bubble test,Use your overflow from your radiator cap unhook get a small clear bottle and put the hose in it start engine and let it get warm if you have bubbles in the bottle your getting compression in your coolant,more than likely a headgasket is starting to go bad, I hope this helps you?
Oct 18, 2009 | 1997 Dodge Neon
Photography Logo
37 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
