Question about Casio DR-T120 Calculator
Tape installation How do I put the paper tape in.
4 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Loading paper tape
I had the same problem. I cut the paper at an extreme angle so that I could grab an end of it as it feed through. I then gave it a gentle tug and noticed that it tried to pull something else with the paper. At this point I knew there was a problem and after disassembling it I noticed that the lower rubber roller had burned a flat spot on it and would not roll anymore. TRASH...
Well not really. I ended up getting a bunch of rubber gromits and reinstalling it and it works great. Not really sure it was worth my time fixing it however.
Let me know if you need further help
Posted on Apr 10, 2008
SOURCE: reloading tape roll on a Casio DR-T120
place the paper sticking out of the top, then close the cover. it will start working; good luck
Posted on Jun 26, 2009
SOURCE: FR-2650 Plus adding machine
How to install paper tape on a adding machine?
Posted on Sep 14, 2009
How do install new tape in a Verifone FD55 model?
you can simply place paper in cradle, making sure the end of the paper has about 3 inch "tail" that you will pull towards you, then close the door, no feeding needed.
Mar 05, 2014 | VeriFone Retail Supplies
I can't get the correction tape to work.. I put it in 1st then the print tape, I'm using Brother brand tapes. .
If the correction does all the movements it is supposed to make and won't lift off you may have a non correctable ribbon or the L/O may be installed wrong the dull side must face the paper.
DickyO
Mar 30, 2010 | Brother SX-4000 Typewriter
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
Reloading tape roll on a Casio DR-T120
Jun 02, 2009 | Casio DR-T120 Calculator
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
Can't get lift off tape to work on my Brother EM530
Very possibly when tou installed it you put it on with the wrong side facing the paper. (Dull side towards the paper
DickyO
Mar 19, 2009 | Brother SX-4000 Typewriter
Installing correction tape
The full spool goes on the L. side of the printer it goes thru guides on both sides of the printer and thr empty goes on the R.
Be sure the dull side of the tape faces the paper.
DickyO
Aug 28, 2008 | Brother ML-100 Typewriter
Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Casio DR-T120 Calculator Logo
37 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
