Question about Water Heaters
My oil water heater bock model 32 E Is in lock out I have pressed the rest button a hand full of times how can I get this going
2 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: Our hot water heater keeps needing to be reset.
overheat stat or fan
Posted on Dec 03, 2009
Testimonial: "That's what we thought, too! Thanks for your advice."
I have no hot water, how do I change the filter in a Bock Water Heater 32E 32 gal oil-fired hot water heater ?
Unfortunately, looking at the manual for the water heater, the filter is a separate item. And the recommended Delavan line filter page just shows a picture and part numbers of the item, not how to remove it.
I suspect it works in such a way that you hold the end nut portion and turn the large nut portion with open end wrenches. You will need the internal filter replacement and possibly new seals, probably in a kit.
Line Filter
You'll want to turn off the power to the oil pump so you don't make a large mess.
Jul 20, 2016 | Water Water Heaters
What is the purpose of the magnesium rod inside the water heater (bock)
These anode rods, sometimes made from aluminum, prevent corrosion. The rod emits ions that line the tank and help prevent corrosion. The rod isn't solid magnesium or aluminum; it has an iron core. If your hot water smells of sulfur (rotten eggs), the anode rod has gone bad or there is a presence of hydrogen sulfur gas that is overwhelming the rod. Usually replacing the rod will stop the odor, but sometimes chlorination of the tank is necessary.
Oct 25, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Hot water tank - Bock model 51E Was working perfectly until a couple hours ago and then stopped. I have a red light indicator on and I've pressed the red button reset and the motor started up for...
Call service technician.
Call Boch Phone: 608/257-2225
http://www.bockwaterheaters.com/technical/engineering.html
I don't see a service manual posted on internet.
Without a service manual showing ohm-readings for testing different parts, you are left guessing which part is problem.
Most water heater manuals today recommend yearly service to catch up on most causes for failure including air in fuel line, dirty or corroded burner parts, defective sensor, loose connection, etc.
Jul 30, 2011 | RTO Bock Water Heaters 51E 50 gal 152,000...
Hello, I have a Bock Model 32E water heater (oil fired). When I take a shower, I have 10 minutes of really hot water and that is it. My water heater will not turn on while I am taking a shower and it...
This has to be one of two problems....
Either the dip tube is not in place properly or the hot and cold are reversed....
That is the ONLY way that you can be having that problem....
Make sure you have another person look at the heater...
Take off the piping on both the hot and cold lines and VERIFY that the dip tube is in place in the cold side, and that there is NO dip tube in the hot side....then also that the pipes are connected correctly...
heatman101
Apr 08, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
My water heater is not turning on at all.....it is three years old
There are many things that could be wrong with an oil fired hot water heater...oil burners are not something that a novice should mess with as they can be very dangerous...
Please hire a por to figure thsi out for you..
heatman101
Jan 30, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Took apart electrode assembly & cleaned--replaced with proper nozzle .75 x 80A- -re-gapped with beckett gauge---was that rite or is there a gauge for the bock water heater or wayne burner? Nees proper...
The nozzle size and gap completely are designed to each burner, if the bock water heater had a becket burner than you would be okay with the gap, if not then what I would do is check the manufactures manual for proper nozzles and gaps of electrode assembly
May 22, 2017 | RTO Bock Water Heaters 32E 32 gal 104,000...
Water heater runs for 40 seconds or so and stops, smell oil oder
Hello STOP!!!!! don't push the reset button any more.You have a ignition/spark problem.You will load the chamber with oil and will cause major problems when it lites off.Replace the ignition TRANSFORMER on the burner.Avalible for (beckett burner) at home depot/lowes.
Sep 20, 2010 | RTO Bock Water Heaters 51E 50 gal 152,000...
My 32E Bock Oil Water Heater will not fire up. What is the gap between the little lighter fingers? Or whatever you call them? We got it to fire once but then it went out again shortly. We have checked...
Hello You have a clogged oil filter or oil line.The (electrode) gap should be left ALONE.The line needs to be blowin out & replace the filter element then the flameout will stop.
Sep 03, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
Water Heaters Logo
46 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
