Question about Dishwashers
Wc140in cda Faulty heater sensor - Dishwashers
2 Suggested Answers
SOURCE: cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Posted on Nov 24, 2012
P1273 Manufacture contr fuel air metering 2004 nissan sentera
P1273 Nissan P1273 Nissan - Air Fuel Ratio Sensor 1 Lean Shift Monitoring Bank 1 Possible causes
- Faulty Air fuel ratio (A/F) sensor 1 Bank 1
- Faulty Air fuel ratio (A/F) sensor 1 heater Bank 1
- Fuel pressure
- Faulty Fuel injector
- Intake air leaks
- Faulty Air Flow Meter
Most probable is you have a bad heater in your upper bank 1 O2 sensor. Replace all of your O2 sensors.
Read more: http://engine-codes.com/p1273_nissan.html#ixzz3lgP7CTD8
Read more: http://engine-codes.com/p1273_nissan.html#ixzz3lgOwiMU8
Aug 27, 2015 | 2004 Nissan Sentra 1.8
Tip
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
source
http://truckmanual.weebly.com/scania-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Faulty O2 sensor heater
heater is part of the 02 sensor. Replace sensor
Feb 03, 2013 | Cars & Trucks
01 vw Jetta trubo 2.0 code p1113
Trouble Code: P1113
O2 Control (Bank 1 Sensor 1) Internal Resistance Too High
Possible Causes:
Oxygen sensor (before catalytic converter) is faulty. Oxygen sensor (behind catalytic converter) is faulty. Oxygen sensor heater (before catalytic converter) is faulty. Oxygen sensor heater (behind catalytic converter) is faulty. Circuit wiring has a short to power or ground. Engine Component Power Supply Relay is faulty . E-box fuses for oxygen sensor are faulty . Leaks present in the exhaust manifold or exhaust pipes. HO2S signal wire and ground wire crossed in connector . HO2S element is fuel contaminated or has failed. ECM has failed .Here is what is listed.
Sep 05, 2012 | Volkswagen Jetta Cars & Trucks
P0037. heater sen. where is it on the engine?
The code is for the heater in the O2 sensor bank one sensor two. That would be the sensor after the catalytic converter on bank one.
It could be the sensor itself or the power supply for the heater.
Aug 25, 2012 | 2006 Mazda MPV
Cda wc140in
Apr 24, 2012 | Dishwashers
WC140IN CONTINUOUS BEEPING AFTER THE FIRST RINSE CYCLE DOESNT DO ANYTHING ELSE. IVE CHECKED FILTERS PIPES AND INLET ETC PLEASE HELP ...
There is a control module behind the face of your cycle selector switch and it probably needs to be replaced
Oct 09, 2011 | Washing Machines
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Opened & cleaned pool. Haward 250 Heater woun't stay on.
Could be a dirty or faulty ignition sensor. This is the sensor that tells the heater that there is a flame burning normally. If that sensor gets dirty or fails, the heater thinks there's no flame even though there is and cuts the gas as a safety measure. Cut the power, remove the cover, and check all the wire connections to be sure the leads are clean and dry and snug. The ignition sensor is near the bottom. If that doesn't work, then the sensor might be faulty rather than dirty. Call a tech to replace it.
May 30, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
