I got this about 10 months ago went to wash my deck and no pressure not been used a lot but not happy with this
Remove and clean the unloader. the Unloader has a large spring hidden under a black vinyl wrap sticking off the side of the pump housing. you do this by prying out the square clip with a screwdriver, then pry out the unloader. the tip of the unloader should push in and out freely about 3/8 inch. if tip is stuck, strike softly with a hammer, grease the o-rings and replace. wah-lah pressure restored!
The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
