Question about Home
Set flashing clock on 2004 acura mdx
Clock flashing in acura mdx need to set
rteemon
  • 578 Answers
SOURCE: leaking Acura 2004 MDX
to find this remove the wipers and and take all those pannel in that area exposing the bottom of the wind shield and have some poor water from to while you look and see where the water is coming in the vehicl''sometime is just a leak in the wind sealing'''hope this help''
Posted on Sep 12, 2009
co7196
  • 3433 Answers
SOURCE: 2006 Acura MDX bluetooth stopped
Bluetooths have batteries, Rechargeable. If it won't hold a charge replace the batt.
Posted on Oct 16, 2009
SOURCE: 2004 Acura MDX Water Leak
The 2002 MDX I worked on turned out to be a drainage problem . Seems the factory installed foam in the bottom of the hinge pillar post which blocked the drain holes . Take off the mud flap , remove enough of the splash shield to access the bottom of the hinge pillar and drill a half inch hole at the front lower corner aiming the drill slightly upward ( be sure to protect the bare metal) .Water gushed out when I did this. For extra ins. remove the kick panels and check for two holes a few inchs from the floor, plug and chaulk these holes. Hope this worksfor you too
Posted on Jan 07, 2010
  • 3 Answers
SOURCE: Need to reset the code my Acura MDX navigation
check the side of the glove box. my TL has it on the outside side panel as you look from the driver side. my honda prelude had the code there as well. hope this helps
Posted on Apr 30, 2010
vetteman3002
  • 2299 Answers
SOURCE: 2004 Acura MDX 3.5 130,000
This could be a couple of different things. I would suggest a tune up. New spark plugs, wires. If that doesn't help then it could be the coils.
Posted on Jan 13, 2011
2004 ACURA MDX VSA and (!) lights are one
You need to have the dealer check the system for fault codes, when the light is turned on a fault code is set im the control modules memory.
Aug 22, 2016 | 2004 Acura MDX
2004 acura mdx 3.5 obd codes
These are all misfire codes. This can be set by clogged EGR passages, clean them first.
Sep 13, 2014 | 2004 Acura MDX
Where is the fuse box on a 2004 acura mdx
On this website you find fuse box diagram and description for Acura MDX (2004)
Acura MDX 2004 fuse box diagram Auto Genius
Dec 31, 2012 | Cars & Trucks
Fuse box locations for 2004 Acura mdx
You can check this website, there is fuse box diagram and description for Acura MDX (2004)
Dec 13, 2011 | 2004 Acura MDX
My 2004 Acura MDX is making a whinning noise. we
the fluid could be burnt and the filter may need to change. You would aslo need to check the air in your tires to see if one of the front tires is low on air, then the next thing would be to check to see if a brake caliper is sticking.
Apr 16, 2010 | 2004 Acura MDX
Oct 16, 2009 | 2006 Acura MDX
Tailgate lights for license plate are not working. 2004 Acura MDX
On this website (link below) you find fuse box diagram and description for Acura MDX (2004)
Jun 09, 2009 | 2008 Acura Mdx
Radio Security Code
I think that your only bet would be to take it to an Acura dealership. The service department should be able to reset the radio.
Sep 10, 2008 | 2004 Acura MDX
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
