Question about Archos ARNOVA 10 Android Tablet
My rca 10 inch tablet connects to the wifi bu seems to have issues with network speed or connections
5 Suggested Answers
  • 358 Answers
SOURCE: how to connect wifi network in archos 28 internet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Posted on Dec 17, 2010
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
Posted on Oct 16, 2011
  • 4 Answers
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12 mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to gather around on the sofa at home or slip into a carry case for when on the go".
Archos Arnova 10 G2
Posted on May 19, 2012
  • 80 Answers
SOURCE: Tablet says i am connected to wifi but cant access anything online
Have you tried mutiple wifi sources to verify its the tablet or just your home wifi, reinstall the wifi drivers if possible....
Posted on Mar 02, 2014
My rca tablet usually works with my internet. Now today different story. My internet is fully operating with all my other devices but won't hold signal with my tablet why?
OK, this is a common issue with Android, even with the Nexus line.
Try to connect again, if it does, check for how long it holds. Usually you can see if it drops by just rolling down from the top.
If there is still issues with it, tap the Airplane mode and leave it on for some 10 seconds, tap it again to turn it off, test the wifi connection again.
Also, you can forget the network, reboot the device and search for wifi. (This means that you have to type the network's password again, as if it was for the first time).
If nothing works, then you will have to factory reset your device. But unfortunately this is a common issue in Android.
Jun 06, 2016 | Tablets & eReaders
Irulu Expro tablet. Where is the Bluetooth setting?
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 ...
https://www.irulu.com/tablet/p-irulu-expro-x1plus-10.1-inch-quad-core-t...
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 Lollipop support Wifi OTG ... Bluetooth: 4.0 ... iRulu Google Android Capacitive Tablet PC(1) ... 1 Comments 0 or 0 people found the following review helpful .... Connect With Us.
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core
https://www.irulu.com/tablet/p-irulu-expro-x2plus-series-android-4.4-hig...
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core Tablet 16GB ROM 10 points Capacitive IPS touch screen Bluetooth 4.2. $89.99 $179.99.
Irulu Tablet - Android Forums at AndroidCentral.com
Dec 26, 2015 | Tablets & eReaders
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
Dec 14, 2015 | RCA 8" Android Tablet w/Dual Tuner
How can I connect to wifi
Go to settings then Wifi if it is not turned on turn it on it should bring up the available networks select your network name it will ask for your password enter your network password and choose connect if it does not. Connect reset your router by unplugging it for 10 sec plug it back in and. Repeat the steps above. If that does not work call your service provider and tell them you need to reset your network password. After resetting your password follow the steps listed to connect to your network.
Jul 26, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
I have a 7 inch RCA tablet that will not connect to my WiFi the internet connect says it is connected but I don't have any bars so it will not allow me to go anywhere.
I've known some tablets not connect to the standard 2.4G wifi but are quite happy on the newer 5G wifi. don't know why.
I've also known some tablets only connect to WEP security or none.
see if you can change the security settings in your router.
Jan 30, 2015 | Tablets & eReaders
Wifi will not connect it sees the network?
Assuming you already know that a password isn't the issue and you know how to handle connecting to a password protected network...
Does your router have mac address filtering turned on? Maybe it's rejecting your tablet because the tablet's mac address list doesn't include the tablet's mac address.
Jan 03, 2015 | ZEEPAD MID Android Tablet 7 Inch WiFi
Wifi for my Tablet
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
Jun 11, 2013 | Tablets & eReaders
Why can't i connect to wifi
not to be mean but often times with those little cheap tablets (I have had a few) the wifi is picky due to cheep part and software(the device).here are some common problems.Does it support the type of network your trying to connect to?is your network key too long? some device dont like itis you network name too long? is your router blocking access?(firewalls, filters,port forwarding, client limits)are you with in 10 feet of the router, wifi on tablet can be limiteddo other device connect to the internet via this methoddo you even have a wireless network of you own?make sure wifi is powered on?hard reset devicethe list of what the issue could be is infinite-Good Luck.
Jan 27, 2013 | Coby Kyros MID70154G 7 Tablet Computer...
Archos ARNOVA 10 Android Tablet Logo
18 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
