Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite bottom freezer ,door spring does not work
795.7105 went to open left door and heard a pop ,then the door did not self close,no spring tension.
  • 12 Answers
SOURCE: Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Posted on Oct 05, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Posted on Feb 06, 2009
  • 363 Answers
SOURCE: 07kenmore elite bottom drawer gaps when fridge is closed
clean all of the freezer seals and all contact points.
Posted on Jul 22, 2009
hiltonjug
  • 612 Answers
SOURCE: Kenmore refregerator lights on/burning even doors are closed
If I understand correctly, you have the bottom freezer with the two doors that open into the fresh food section. Also you have to open one of the two doors first in order to get into the fresh food section. If i ma correct. The switch on the door you have to open first to get into the fresh food section is bad. This is why it makes not difference if you hold both in. The switch on the second door does something else. You will need to replace the switch that the first. You can test this switch by, take the switch out. They are tricky to get out. Take a putty knife and slide it under one end of the switch, push in while you are prying outward. It should pop out. There should be three wires going to the switch. One of the wires is hot (110 Volts), one goes to the fan inside the fridge and the other goes to the light. (The switch operates like this. When you close the door, it turns the light off and the fan on. When you open the door, it turns the fan off and the light on.) Once you find out which one is hot, connect one of the others to it. If the fan comes on try connecting the hot to the other wire. The light in the fridge should turn off. If so replace the switch. I hope you can understand the way I tried to explain.
Please rate solution
Posted on Sep 05, 2009
SOURCE: Kenmore/Elite Model 795.7756,7757 Trio:
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Posted on Sep 27, 2010
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
Freezer door does not close all the way
Remove the tray, pull door all the way out and check to see if it is spare. Sometimes the gears jump causeing one side to seal and the other dosent. If that is the issue, use pressure to square door
Aug 19, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Oasis Washer Mod #110.27082601 Ser # CT1170582. I went to put the lid down and heard a "pop" type sound, and now the lid won't stay up. Everything else is working properly, and the...
Hello Chrissym1313,
Taken straight from the APPLIANCEPARTSPROS.COM
website... (Left & Right hinge Springs)
Hi--the lid on my Kenmore elite washer does not stay open on its own anymore--from what I have read-sounds like I need new hinge lid springs--can you tell me part #'s and how I would go about replacing those--thnx!!
Mike J for Model Number 110.28082700
Answer Hello Mike. You will need to order WP8580114 and WP8580115 for the unit.
Cross Reference Information
Part Number WP8580115 (AP6013571) replaces 8563961, 8580115, PS11746797, B008DK65SA, B002M647S6, B072YYQ2TQ.
Right hinge spring:
http://www.appliancepartspros.com/whirlpool-hinge-spring-rgt-wp8580115-ap6013571.html
Left hinge spring:
Whirlpool WP8580114 Hinge Left AppliancePartsPros com
Hope this helps
Carnac the Magnificent
Once you have your absolute part numbers... Then you can go SHOPPING... (Left: on eBay $25.50 plus tax & shipping)
New OEM Whirlpool Kenmore Washer Door Hinge 8580114 WP8580114 LH eBay
Right hinge
Amazon com Kenmore Elite W8580115 Washer Lid Hinge Home Improvement
RH hinge on PARTSELECT... ($39.20 plus tax & shipping)
Whirlpool WP8580115 Hinge PartSelect
Dec 18, 2017 | Washing Machines
Hi. The bottom freezer light won't turn on. I checked the bulb by putting it in another appliance an it wordked. What gives?
We have the same issue with the 22.4 Cu Ft Kenmore elite bottom freezer. Has anyone figured out the problem? Very frustrating..We have unplugged the fridge..nothing. checked to make sure it was getting power to the light socket..all good. We accidently left the freezer door open a little. maybe 15 minutes..we looked and the freezer light came on..closed the door and opened it again, the light still came on..got up the next morning and no light again..Sure dont want to spend $75.00 for a sears tech to come look at it...
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Right door pops open when left door closes
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
