Question about Kitchen Appliances - Others
Britta Timer not working
How to clean a Rowenta steamer
WHen cold tilt over sink and empty and rince every 3-5 uses depending on how much you use it. Water sitting in the tank gets moldy and bad, rinse tank and use Britta type filtered water only.
Jun 18, 2014 | Rowenta Commercial Garment Steamer - White
Britta filter beeping?
Most high end water filters have a timer or sensor that tells you when to replace the cartridge. Are there any lights flashing or does the beeping appear to be a code. If you can't figure it out, go to my website www.60cubits.com and leave me a message with the model number.
Jun 21, 2013 | Kitchen Appliances - Others
Vkj476 BReville hot cup with variable dispense. How do you change the filted britta filter
The Breville VKJ476 Hot Cup with Variable Dispenser does not require a filter so will not take a Brita filter.
Mar 21, 2013 | Breville Hot Cup With Variable Dispenser...
The on/off button quit working. I can't manually turn lights on/off. In wall timer ST01AC
Thank you for including timer model number.
You have almond-colored ST01AC timer that worked before and then stopped working.
The manual override no longer turns lights on-and-off.
Manual override works by pushing in timer door, and also by pushing on-off button on face of timer.
1) Try pushing on-off button directly instead of timer door, in case little plastic point on timer door has worn down. If timer door is worn down, maybe add a few layers of tape so door can push button again.
2) If timer on-off button is not working, then timer may be defective -or- timer CR2 battery needs to be replaced, and then timer reset and reprogrammed.
3) Defective timer: timer has 1 year limited warranty against workmanship defect
http://www.intermatic.com/customer%20service.aspx
4) Replace CR2 battery, reset timer, and reprogram timer and see if functionality is restored.
If timer is not restored, then timer is going bad.
Open following link for illustration of battery replacement, steps for resetting timer, and illustrated re-programming steps.
http://waterheatertimer.org/ST01C-program.html#battery
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Timer runs constantly. Runs cycle then shuts off and shortly later restaRTS.
Posted under GE 15069 countdown timer.
Unknown if this is new timer that is wired wrong or if load has interference, or existing timer that stopped working.
If new timer, then check wiring: This timer is for single-pole application only and requires neutral wire.
http://waterheatertimer.org/GE-timers-and-manuals.html#15067
Then check for line interference by moving timer to different Load, for example ordinary incandescent light bulb.
Make sure slide switch is set to Timer.
Slide switch works as ordinary on-off switch, so see if slide switch works correctly.
If timer stopped working:
Feel timer if it is warm to touch indicating overload or internal timer short.
Timer is rated for 1/2 HP at 120Volts. Check nameplate on motor for HP.
Check for short in line by temporarily replacing timer with on-off switch, and check wire nut connections.
Move timer to different Load, for example ordinary incandescent light bulb.
If timer has gone bad, then return it to Home Depot and swap for different timer.
If load interference is problem, then buy mechanical spring-type countdown timer like Intermatic FD60
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Aug 03, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Hello! My canon iP 2702 printer is not working and showing the Error 5200. I already re-installed the software but the error still remains. I would be very happy about some other advise! Thanks, Britta
Hello thanks for using FixYa
Error 5200 is a service error
Follow this solution step by step to solve the error:
  • With the printer turned on,unplug it
  • Open the top and bring the ink cartridge holder to the middle
  • Raise the gray bar and remove the print head assembly with the cartridges in it
  • Lower the gray bar with the head missing and close the top with the head out
  • Restore the power,wait till the printer starts
  • It will tell you to put in the cartridges
  • Restore the print head, close the top and the printer should resume working
I hope this solution will helpful fopr you.
Thanks and Keep Using FixYa
Mar 17, 2011 | Canon Pixma iP2700 InkJet Photo Printer
We have owned a Britta for over 30 years. Recently when changing filters the water has a greenish color. Hoe do we get rid of it? Is it safe to drink?
If you mean a water softner on tap, then you will need to sanitize it with Sodium Metabisulphate or similar. Fill the unit, not the filter, with a solution and leave for 10 minutes then flush it slowly through the pipes, Baby sterilization liquid will work. You have to remove the algae.
It probably is safe to drink but I wouldn't!
Hope that helps.
Feb 16, 2011 | Microwave Ovens
Instructions are not clear. Cannot get the time to work.
Add a comment with clear description of the timer. Say what buttons or dials are on the timer. If timer plugs-in or is in-wall. If timer is indoor or outdoor. Describe the shape of timer, and what timer turns on-and-off. Say if you are having a problem wiring the timer or programming the timer or setting the timer. Tell us if the timer was working before and stopped working, or if this is a new timer. If this is a new timer, then also say what brand and number the timer is.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 07, 2011 | Hardware & Accessories
Instructions for kettle
Instructions are not available for download.
Use form here (click to open), to request instructions from manufacturer's website.
Feb 06, 2009 | Breville Kitchen Appliances - Others
Panasonic kx-fpg376
more then likely the sending fax had a problem and did not send you the complete fax. You should have them resend the page you're missing.
Hope that helps...
Jun 19, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
