Question about Samsung Dishwashers
DMT800RHS/XAA 9e error code
9e error code
3 Suggested Answers
SOURCE: 9E error code on dmt800rhs dishwasher
I also had the 9E error code on my Samsung dishwasher DMT800RHS mmodel. I had to call Samsung and the nearest authorized Samsung service representative came to my house last Tuesday, January 29, 2013. The cost of the call is $100 which really annoyed me off considering the dishwasher is only 1 1/2 years old. Two South Korean guys showed up and to fix the problem just press down on the Heavy, Delicate and Power button at the same time for a few seconds and a menu will appear on the top left hand corner of the panel. Scroll down the menu by pressing the Normal button until you reach "FT" and the dishwasher will automatically fill up and then autimatically drain. If it does not drain then scroll down to "S" and the dishwasher will drain. Thsi should get rid of the 9E error message and your dishwasher will work fine but if not you have to repeat the procedure maybe 2 or 3 times until the 9E error message disappears. If you constantly get the 9E error message then you may need to replace the part which is about $60. The part is extremely sensitive to either hard water or food particles which is why the 9E error message appears. Therefore, scrape your dishes thoroughly so the food particles are minimized and the sensor does not go off which causes the 9E error message.
Posted on Feb 02, 2013
I had same 9E low water level error. Removed the lower nozzle, then the plate at that bottom (lots of screws to remove) that covers the float. On the underside of that plate was a thin round piece of rubber that I think you would call a gasket. It was far to big and excess gasket was outside of the groove made for it. The excess was in the area around the float. I figure it was interfering with float operation. I snipped it and retreaded it into the groove. I have not had a 9E error since and have cancelled service call that would have cost me min $104.
Posted on Jun 16, 2013
Samsung dishwasher code 9E
Internet search "Samsung dishwasher 9e error code". Many videos to watch to show you how to fix the problem yourself.
Sep 05, 2015 | Samsung DMT800RHS Dishwasher
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
Samsung dmt800rhs errorcode 9e
http://www.youtube.com/watch?v=HXHRPd8VisE The water level float switch needs to be cleaned. There is a micro switch on the assembly don't get the switch wet. This video will show you what to do.
May 06, 2014 | Samsung DMT800RHS Dishwasher
ERROR CODE 9E
What is your model number?
Mar 13, 2013 | Maytag Refrigerators
Nov 21, 2012 | Samsung DMT800RHS Semi-Integrated...
Error 9E 09
Error 9E 09
9E : Elevator range out of specification
Primary: Library Enclosure
Secondary: Library Controller Card
09 : Error elevator init
Nov 02, 2012 | IBM System Storage TS3200 Tape Library...
Samsung dmt800rhs error code se
Thank-you so much I was able to fix the problem. there was a small piece of plastic stuck in the pump house which was connected to the pump. Hopefully no more 5e errors ):
-Abdul
Oct 29, 2012 | Samsung DMT800RHS Dishwasher
Error code 9E What does that mean? Cannot find tech sheet
9E code is a door switch circuit problem.
You can check the wiring and connections and the door switch.
If the problem is not isolated to one or more of these parts then the control board is malfunctioning and must be replaced.
The manual states "unplug the dryer for 1 minute" "reconnect and if the problem re-occurs to check the components.
Maytag has a special circuit board that can be plugged in to evaluate the existing circuit board. Only Maytag certified techs have these test boards, and not all of them have it.
Check your door switch and wires.
The door switch is a inexpensive part compared to the cost of the circuit board. If in doubt, replace the door switch before proceeding.
Door switch part # y305753 and cost about $20.00
Mar 20, 2009 | Maytag Dryers
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Apr 03, 2008 | Car Audio & Video
Dishwashers Logo
41 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
