Question about Candy AQ130 Front Load Washer
Candy sylena Leaking water - Candy AQ130 Front Load Washer
Why water is leaking from bottom of the washing machine
it easy .look in and wach the falling drops coming from the inlet water or from the drainage hose and pump.Whatever it is u can handle it.
Jun 24, 2015 | Candy Washing Machines
Candy sylena
Type in "Sears Parts Direct" into your search engine, and type in your model number, and you will find a instruction manual for sale.
Be blessed.
May 19, 2014 | Dishwashers
Water leaking from the front door during the cydle
check near top of drum where water enters machine that spout also needs to be kept clean. another possible problem could be the seal on door or drum could be loose or ripped check them both.
Jan 08, 2014 | Candy Washing Machines
Hard candy did not harden
  • Sometimes the boiling sugar and water mixture appears to break just before it reaches a temperature stage. If this happens, take it off the heat immediately and stir it gently. You should be able to get it to recombine. Use a medium-high heat so the syrup cooks relatively quickly.
  • Also, be sure you're using high quality butter - never margarines, which may contain too much water for candy making.
  • If you are in a very humid climate or a rainy one, choose drier days for candy-making. Excess water - which can even come from the air, can also cause butter/sugar syrups to break.
    See http://baking911.com/learn/baked-goods/candy/problems-and-solutions
Dec 18, 2011 | Candy Washing Machines
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
Nov 23, 2010 | Candy DFI Plan Built-In Dishwasher
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Leaking water
Maybe it leaks from te heating element. Happends often on older Candy machines!
Jan 22, 2008 | Candy AQ130 Front Load Washer
Dishwasher leaking - Candy CD474
From you're description it seems that the water pump is bad, Some where their is a tag with the Model# and serial# then go to Searspartsdirect.com
Oct 05, 2017 | Dishwashers
Candy AQ130 Front Load Washer Logo
21 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
