How to change region code on dvd
I have a Sandstrom S1DVD12E dvd player. And I whish to be able to play dvd disks from more than one region
bluegreenash
  • 661 Answers
SOURCE: dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Posted on Nov 03, 2007
  • 86 Answers
SOURCE: Changing region on a DVD player
You did not specify what kind of DVD player this is? Since you said player, and not drive, then I will assume this is a dvd player you hook up to your TV, not install in a computer.
Simple answer, you can not change the region code on a DVD player, unless there is a known hack listed on a website.
Therefore, your only option, is get a region free dvd player. They are cheap and easy to get on amazon.
here is one for $30:
http://www.amazon.com/Philips-DVP642-DivX-Certified-Progressive-Scan-Player/dp/B000204SWE/ref=pd_sim_e?ie=UTF8&qid=1196024533&sr=8-9
Posted on Nov 25, 2007
jaffa012001
  • 376 Answers
SOURCE: Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Posted on Aug 12, 2008
  • 7 Answers
SOURCE: Unlocking of region codes for Philips DVP 3260K DVD player
http://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
have a look here and see if it helps
good luck
Posted on Nov 26, 2008
SOURCE: LG Blu-Ray BD-370 unlock codes
http://www.multi-region.net/lg_5931
Posted on May 01, 2009
What is the code sony dvd?
What do you mean with a code? just put a DVD you bought in the player and play it. For region codes look here:
DVD region code
Be aware you can't change them (some allow you change it once, but you can't even put it back to the former code)
If you want to use disks you burned yourself, first make sure you did put a DVD compatible format on the disk and not just a format you can play on your computer to tablet.
Mar 31, 2015 | Sony Televison & Video
I have bought a dvd from America and it is saying error region codes. Can you please help?
Your dvd is probably region 1 which is US and Canada this is known as NTSC format. Your player, because you are elsewhere, only plays PAL formats (usually Europe and such). Unfortunately the only way to play the DVD is to buy a NTSC compatible player.
Oct 02, 2009 | Computers & Internet
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
Sony dvd player
DVD player will play DVD disk according to assigned region code.
You can see DVD-NS330 region code at rear of player, where model and serial number is written, region code would be written in globe mark.
Jan 22, 2009 | Sony DVP-NS330 DVD Player
Change dvd player region to multi region
Try this procedure
. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Dec 05, 2008 | Philips DVP5140 DVD Player
Can't play region 2 dvd's on my player
Newer DVD224 is actually DVD-224ss - small print on front of manual. There are two possible hacks:
DVD224SS (This worked for me)
1. Open the DVD tray
2. Press STOP button on the remote control
3. Press 70
4. Press MENU
5. Use the numeric keypad to select your region code number (0 – 6).
OR
DVD224 (224SS)
2. Press STOP button of remote control
3. Press the digit number buttons “2008” of remote control.
4. Press MENU
Region code will appear, select your region code number.
Jun 22, 2008 | Coby DVD-224 DVD Player
No disk
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
Dvd region codes
Nov 03, 2007 | Televison & Video
REGION CODE
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number 0
6. Press the “Setup” button to exit.
DVD283
1) Open DVD Tray
2) Press STOP
3) Press 70 plus region code 0 Example 700. Region
5) Wait five (5) seconds; the unit will automatically exit the region code menu.
Nov 02, 2007 | Coby DVD-283 DVD Player
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Mar 31, 2007 | NAD C541 CD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
