Question about Sony DAR-X1R Theater System
Loading startup - Sony DAR-X1R Theater System
She gets an error message when booting up:: Fail to load language file
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
Oct 05, 2012 | Acer Aspire Computers & Internet
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
How to remove ask for genuine microsoft software
1. Restart your com­puter, hit F8 before win­dows load­ing screen to go into the safe mode menu.2. Select Safe mode (not with net­work­ing, and not with com­mand prompt)
3. Once your in win­dows, goto START>RUN> type "regedit" (with­out the qou­ta­tion marks) and hit ENTER.
4. Goto EDIT, select FIND
5. Search for wgatray.exe, delete any ref­er­ence found, (after it finds it the ini­tial first time, just hit F3 to con­tinue the search. Con­tinue to delete any­thing it stops on.
6. Scroll all the way back up inthe reg­istry edi­tor, and select My Com­puter (one click. not two) and start a new FIND, this time were look­ing for Wga­l­o­gon, again, delete any ref­er­ences found.
7. Lastly, again, click on My com­puter, and start a new FIND, search­ing for LegitCheckControl.dll , again delete any ref­er­ences found.
8. Reboot and your fin­ished, if not, you may have missed a reg­istry entry.
BTW you should be able to con­tinue to down­load Win­dows update (when set to auto­mat­i­cally down­load an install).
Aug 20, 2011 | Microsoft Windows XP Professional for PC
We have an inglis washing machine we bought may of 2009 and now it will not spin. If you turn the tub it will and also if the load is very light it will spin. Can you help?
inglis is a whirlpool brand, and your within their 1 year coverage, you might contact them and see if they will send out a tech. doesnt solve your problem, but it sounds like a motor problem to me.
Mar 24, 2010 | Whirlpool Inglis IP4400 Washer
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
My starviue 4usb wont load all im get ing is
http://forums.afterdawn.com/thread_view.cfm/753769 this is a link read the second box will tell u how to do it but will be difficult enough id say good luck
Jun 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Inglis washer LO-38002
any appliance parts store. it should be a stocked item.
Jan 10, 2008 | Kenmore 22422 Top Load Washer
Sony DAR-X1R Theater System Logo
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
