Question about Drills
Fiona westmac corn drill - Drills
What is the corn and oil amount for treat time popcorn popper tpc 603
I am not fimiliar with that brand . the corn/oil ratio is 3 to 1 so if you add 1-1/2 cups (12oz.) of corn with 4 oz. of oil the popping cycle from the time you dump the corn and oil in to when you dump it shoul be around 3-1/2 min. if its much longer its too much so try 8 oz of corn and 2-1/2 oz. of oil. By you using this test or formula I am assuming the kettle thermostat is set correctly already.
Jan 22, 2016 | Kitchen Appliances - Others
How do I freeze corn on the cob?
remove husks & silk.
Blanch the ears of corn in boiling water; the National Center for Home Preservation advises blanching for approximately 7 minutes for ears that are up to 1-1/4 inches in diameter, between 7 and 9 minutes for ears that are between 1-1/4 and 1-1/2 inches in diameter and 9 to 11 minutes for ears larger than 1-1/2 inches in diameter. Pull the ears of corn from the boiling water with tongs after the proper blanching time has been met.
Plunge the hot ears of corn directly into the ice water immediately after blanching. Allow the ears of corn to cool for the same amount of time used to blanch them.
Dry each ear of corn completely with paper towels before freezing. This reduces the amount of ice crystal formation on the corn while freezing, which helps prevent the corn from becoming mushy.
place in containers for freezing( I use freezer bags).
place in
Sep 04, 2014 | Home
What is the best recipe for cooking corn
There are literally thousands of recipes for cooking corn on the internet. Here is just one of them, if this is not to your liking chose from the wide choice by just Googling for Corn recipes.
Corn on the cob - grilled with Chili and Basil Butter
4 large ears of corn on the cob
Chili and basil butter
125 gr butter
1 large chili
5 large basil leaves
1 clove garlic - crushed
salt/pepper
Peel back the husks from the corn, leaving them attached at the base. Remove silky hair from corn and discard. Fold husks back over corn and tie with a piece of string to keep closed. Some people say you must soak the corn in water for a couple of hours..well, I did not and I think the result was still perfect. Heat your grill, BBQ or griddle panir?t=widgetsamazon-20&l=btl&camp=213689&creative=392969&o=1&a=b0000936k2 until hot and place the corn on the grill.ir?t=widgetsamazon-20&l=btl&camp=213689&creative=392969&o=1&a=b00004w499
In a food processorir?t=widgetsamazon-20&l=btl&camp=213689&creative=392969&o=1&a=b0000645ym, add all the ingredients for the butter and pulse until well blended. Use for basting the corn while grilling.
Turn the corn frequently while grilling, all the time basting the corn. Serve with more of that delicious butter as a side dish to a BBQ or as a wholesome vegetarian supper!
Apr 26, 2011 | Dryers
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
How much oil or corn do you use in the Back to Basics Pop Corn Popper for the stove
unless you have the instruction manual, only trial-and-error will tell you. Start with 2 tablespoons of oil and 1/2 cup of corn kernals. If there is oil left after the corn is popped, decrease the amount of oil by a teaspoon. If the popped corn is burned, increase the oil by a teaspoon. As for the corn, if the pot is full when the popping is done, 1/2 cup is the right amount. If the popped corn over flows, 1/2 cup is too much. Vary the oil and corn until you get it right. Good luck! I love popcorn, so I wish you the best.
Feb 02, 2010 | Back to Basics 6112304 Popcorn Maker
Hi I cant unlock my daughters sony erikson
Hi Fiona, go to davinciteam.com and it''ll cost you around £15.
Aug 25, 2009 | Cell Phones
Half the Kernals spit out uncooked
It coud be 2 things. Either a low grade of popping corn, or old popping corn. Hot air poppers blow the same temperature, until you shut them off. Although the better grades of popping corn cost a good amount more, you don't throw half of it away. Once the popping corn container has been opened, you should use it up within about 3 months. The internal moisture content is what determines whether corn will pop or not. Too much or too little moisture will not allow the corn to pop.
Aug 23, 2009 | Toastess Hot-Air Corn Popper Popcorn Maker
Need instructions for Toastess cinema popper TCP-6L
1 tbsp veggie oil for 1/3c. corn
2 tbsp oil for 2/3c corn
3 tbsp oil for 1 cup corn
i use 2/3 c as the max because it completely fills the bowl if you use 1 cup be sure to do it in batches or the machine will over flow.
happy popping
Aug 30, 2008 | Toastess TCP-6L Popcorn Maker
Cell phone area code for Big Corn Island, Nicaragua...???
try to customer care and ask her fo code or contacs std operator or tellephone dierictory
Mar 22, 2008 | Cell Phones
Drills Logo
35 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
