Question about Cell Phones
Samsung 2252 speakar problem solution - Cell Phones
Speakar not wark
try to dissambly the device and resambly again maybe this solve, if problem persist try to change the speaker, if you are not technition search on you tube to see how to do all procedure.
Jun 28, 2012 | Samsung Star GT-S5233 Cell Phone
I can't find the manual, and I was wondering how far away you can talk on the BellSouth Walkie Talkies Model 2252?
The range of the BellSouth 2252 will depend on the frequency and the surrounding environment. If you get the FCC license and operate in the GMRS range, then the radios will have a maximum of a 2 mile range. The surroundings will matter: hills, buildings, etc. will shorten the range.
If you are using the FRS frequencies, your range will be significantly shorter (again depending on the surroundings). I'd guess no more than 1/2 mile line of sight.
I hope this helps.
(who uses another brands of two-way radios and the ones with a 5 mile GMRS range work over 1/2-3/4 of a mile depending on hills. The ones with a shorter range can't communicate with someone at the far end of the property. It's about 3/4 mile from the road to the back fence.)
Jul 14, 2011 | BellSouth 2252BK (22 Channels) 2-Way Radio
Speakar not working
first check ur speaker volume and other sound setting if everything r ok. then my guess is may be ur speaker line cut from ur phone circuit or damaged ur speaker . so u need a new speaker for ur phone and replace it, thanks
Jul 24, 2009 | Nokia 6600
Compaq laptop speakar is not working
IF you are able to hear sound from other speaker, it cannot be a configuration or software problem It sounds like a hardware failure. Get it serviced or replaced.
Jan 27, 2009 | Compaq Presario Notebook
How do i change the main display?
go to settings, then to phone settings, then to quick search. select yes. now when you open you phone type in 25276 (alarm) on your keypad and press the down button. sholud come up with alarm. or 2252 (calc) for calculator
Jan 07, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Locked
0000 is the universal code ,else download go to the mob. shop near u and they have some software to open it..charges r nominal 50-100 rs.
Dec 06, 2007 | Philips 2252 Twin Cordless Phone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
