Question about Microwave Ovens
Instruction Manual, Kenmore 148.12170 - Microwave Ovens
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
I just bought an 1100 watt microwave oven from K-mart and when I opened th box there was no manual in the box. The microwave number is 66222. how can I get a manual
Many Kenmore appliance manuals are available from Manage My Life. com . The Kenmore 66222 manual is here: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . A printed copy is available from Sears Parts Direct: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . Scroll down for the manual; it's the fourth from the bottom.
Unless the microwave was labeled as a refurbished or open box unit, I'd contact K-mart customer service and see if they'll send you a replacement manual before you order one.
I hope this helps.
Jul 15, 2011 | Kenmore 66222 Microwave Oven
Need installation bracket for kenmore microwave model 80882. Bought as an open box item and no installation or owner's manual or mounting bracket
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 25, 2011 | Kenmore 80882 Microwave Oven
I have a Kenmore Over the range microwave oven--the turn table stopped turning. I think there might be a way to stop and start the turntable, but do not have the manual.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
I hope this helps.
I suspect the turntable motor has failed.
Jan 05, 2011 | Kenmore Microwave Ovens
I have a Kenmore microwave model 882252 from 1992 and I am trying to find out the size of the microwave. Any suggestions?
Download an instruction booklet from the manufacturers web site, that should have the details.
Dec 17, 2010 | Kenmore Microwave Ovens
I need the service manual for a model 911.49489992 Microwave. This oven is part of an oven/microwave unit. I have ordered the magnatron but Sears did not have the service manual or instruction sheet for...
I am assuming the case from the microwave has been removed.
Ensure the capacitor is discharged!
Remove the connections from the rear of the magnetron and remember which way around they go, a photo on a phone camera is very usefull!
Undo the fixing screws and remove the magnetron from the cavity. Replacement is the reverse procedure.
Hope that helps.
Nov 06, 2010 | Kenmore Microwave Ovens
I bought a used over the hood microwave, kenmore. It doesnt seem to cook very fast. Everything else works fine. What could be the problem and could it be expensive? Thanks Caryl
It could be a low power oven ... or it could be set to a low power ... If it is set to low power, you might change it by following the manufacturers instruction.
You can find this information by going to the manufacturers web site and searching this oven
if it is low power ... it is designed to be a low power machine and it is not feasible to change it.
There are several Kenmore experts around here ... they may have a different call.
I suggest you google Kenmore Microwave or go to the sears website and look for your owner manual
I hope yo find a smidgin or more of value in this comment.
Oct 16, 2009 | Microwave Ovens
Need instruction manual
Try this link: http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0310102.pdf
If that does not work go to www.searspartsdirect.com and search by model number.  Select the manual button at the right side of the page and if you do not see the manual on that page enter the model number in the search field at the top of that page.  The manual in PDF format is there.
May 27, 2009 | Kenmore 64002 Microwave Oven
Manual
RE: Kenmore Microwave Model 5668878411 "Instruction Manual"
Kenmore Customer Care @ http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AF
Click on the above link to order a manual or download a free manual.
jackiaria
Mar 01, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
