Question about MCM Repair Brass T fitting with nipple to create twin outlet from a single regulator in si
Need outlet fitting for my pw0701210 - MCM Repair Brass T fitting with nipple to create twin outlet from a single regulator in si
The outlets were removed need to put them back on a gp3300 generac generator
You can buy new outlets and other parts for your Generac GP3300 on this page: https://www.generatorguru.com/gp3300/?sort=featured
If you need advice on fitting please contact us. :)
Apr 07, 2017 | Generac Electrical Supplies
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
Sep 22, 2013 | Hardware & Accessories
My in-ground pool pump...Sta-rite 11/2 hp...leaks at the outlet fitting. Changed fitting twice, using teflon tape as recommended...still leaks.
I don't recommend Teflon tape as it places outward pressure on the pump and can cause the pump body to crack. and if that happens the pump body will need to be replaced. I use black RTV silicone. smooshing it into the threads of both fittings and hand tightening the fitting.. then the glue the pipe as normal
REMEMBER to prime the pump after any pump repair !!
Teflon tape works well on metal pump like well and irrigation, they are a high pressure pump and are generally cast iron tanks.
Jay the pool pump motor repair guy longwood Florida 32750
Mar 14, 2012 | Sta Rite Pool & Spa
I do not have an electrical outlet that fits the plug.what shall i do .
As long as the outlet tou have is 240 volts you can buy a new cord to wire into your dryer to fit that outlet......
Aug 10, 2010 | Kenmore 63942 Dryer
Temp gauge does not move. Heat works. No Coolant leaks. Coolant level appears normal.
your thermostat is bad
heres how to fix it
  1. Drain the cooling system.
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
To install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks.
Jan 23, 2010 | 2001 Oldsmobile Alero
Where is the thermostat located on a pontiac grand am 2004 v6 3400
3.4L Engine
To install:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | 2002 Pontiac Grand Am
How do i hook up the water supply. witch is the inlet and outlet?
Most newer units have a brass inlet on the valve and a plastic outlet. Older modles have a plastic garder hose type fitting for inlet and same smaller plastic thread for outlet Some models have push in connectors called John Guess fittings the do not require threading.
Sep 26, 2009 | Freezers
99 Chevy 1500 heater core inlet hose male fitting broke
well you may need to replace the entire heater core if the remaining inlet/outlet nipple is not long enough. common problem many people have
May 27, 2009 | 1999 Chevrolet Silverado 1500
Kenmore dryer plug does not fit
Probably a 220V machine and you have a 110 outlet. Or Vice-Versa.
Feb 26, 2009 | Kenmore 63942 Dryer
MCM Repair Brass T fitting with nipple to create twin outlet from a single regulator in si Logo
69 people viewed this question
Top MCM Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a MCM Grilling Expert? Answer questions, earn points and help others
