Question about Samsung Series S24B30BL 23.6-Inch Screen LCD Monitor
Monitor won't start. It worked yesterday
I turned the computer on and the monitor is black. The blue light won't even come on
  • 23 Answers
SOURCE: Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Posted on Aug 14, 2009
  • 1684 Answers
SOURCE: My computer is on and working, but the monitor is
The power supply in the monitor is blown. We have a step by step repair guide posted on our web site at: www.ccl-la.com/badcaps.htm The guide shows you how to open the monitor and replace the defective capacitors and get back going.
Check it out. I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 21, 2009
SOURCE: Samsung 540N monitor. Takes more time to start the display
this is capacitors problems inside the monitor. If you have some tools , screwdrivers, soldering iron and some experience, open carefull the back of your monitor after to unplug from the outlet.
you will see in power supply board a capacitor who which the top has changed . replace that capacitor.
Posted on Sep 12, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
SOURCE: Samsung 953BW monitor. Blue light is flashing but no picture.
hi, i have the same problem...any solution?
Posted on Jun 26, 2010
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
The monitor fades to black, a few seconds after I turn the pc on (even before starting windows); the blue button keeps on. When I turn it off, and then turn it on again, it works for a few seconds, then it...
Simplest solution first; check your cables. If the connections are good, but it still doesn't work, try your monitor with another computer. If it works, you need to update the drivers on your computer. If it doesn't, the problem is with the monitor. If your computer needs drivers from LG for the monitor, you need access to another computer (or another monitor to go online). Go to LG's website and look for SUPPORT. Download drivers for your monitor specific to your operating system (Windows, Mac OSX, etc.) and install.
Mar 02, 2011 | LG W2252TQ Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Mine similar except the blue light stays on ,monitor goes black
Have you tested the monitor? The monitor could be faulty. Try hooking up the computer to another monitor or another computer up to that monitor if possible. If the monitor is testing good then make sure all USB devices are disconnected and try to boot again. Then open the case and blow out any dust. Check the motherboard screws are tight. If the screws holding the motherboard to the case are loose it can cause a grounding issue. Then swap out the power supply with a working one and see if that fixes it. Disconnect hardware one at a time and re-boot. One of the devices...cd-rom,harddrive,ect could be faulty. Make sure the video card is fully seated and test the card in another working computer or test a working card in that computer. If it has on-board video then install a video card if available and see if it works. If none of these things work then the board is bad and needs replacement.
Sep 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Monitor Turns Black
Hi
you have cold solder to PCB and you have to resolder the Cold solder to PCB
Thanks!
Jul 03, 2009 | Computers & Internet
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
HP vs19e Computer turns on Monitor stays Black. blue light blinks
Same here- I understand that the capacitors are bad and need to be replaced. I am going to undertake it myself. Radio Shack sells them.
Apr 08, 2009 | HP vs19 19" LCD Monitor
Samsung Series S24B30BL 23.6-Inch Screen LCD Monitor Logo
19 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
