Question about Nintendo Wii Console
The wii remotes wont work and their all charged and it only light
    Sergeant:
  • 321 Answers
Try syncing the remote there should be sync buttons on both the remote and wii hit them both to sync
Posted on Jun 19, 2009
  • 104 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-38
Posted on Jul 22, 2009
4 Suggested Answers
scrodamoon
  • 659 Answers
SOURCE: wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Posted on Aug 01, 2008
  • 26 Answers
SOURCE: my wii remote wont work
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
eRealm
  • 16 Answers
SOURCE: wii remotes will not charge in the charging station
your wii remotes might have a shortage in them....i advise you to buy new or used remotes
Posted on Oct 02, 2009
If the wii remotes aren't working, responding, or charging, can the remotes be reset or do I need new batteries?
First you will meed 2 try new batteries then you will need to press the 'Red' button
located on the Wii console to 'Re-tune' in the Controllers
How to Sync the Wii Remote Standard Mode Wii and Wii mini Nintendo...
May 11, 2014 | Video Game Consoles & Games
Wii remote is not charging. I have 2 remotes, one of them does not charge. Basically, when I charge it, it charges for a few seconds then it turns to the green light (meaning it's done charging) so it...
If you have had the "battery" for a long time, it could be that it can no longer carry a charge. Rechargeable batteries' charge grow shorter over time. If you still use the Wii/Wii U regularly, I suggest rechargeable AA batteries+charger (If you don't have them already). AA batteries work in other devices so even if you stop using the Wii, the batteries will still work in remote controls, clocks, flashlights etc unlike a WiiMote Battery pack.
Sep 10, 2017 | Nintendo Wii Remote Controller
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
Apr 30, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Wii remotes will not charge in the charging station
Oct 02, 2009 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii remote doesn't come on. Blue lights don't
Thanks for using FixYa!
If the blue light on your Wii controller doesn't light up, its possible that it ran out of battery charge. If you think your battery is fully charged. try to buy a set of disposable battery and see if they will work. If they do work, it means your rechargeable batteries have gone bad.
Have a great day.
-HotRatchet
Jul 28, 2009 | Nintendo Wii Console
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
My wii remote wont work
Jun 21, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
139 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
