Question about Thule 2000 Ford Taurus - Wagon, with factory roof track - Base Rack System
Need to replace license plate bulb on 2005 pathfinder
What type of license plate socket fuse do i need to replace
Hello Juani Ornelas,
just a Scientific Wild Guess...
Most likely you are NOT looking at a FUSE FAILURE.
There is NOT a separate fuse for your license.
Free drawings are available at the BBB Industries site below.
You are looking for a bad sockette either electrically joined together ... it is a bulb or socket issue...!!
2005 CHRYSLER PACIFICA 3 8L V6 License Plate Lamp Bulb RockAuto
More Information for PHILIPS 168CV
Free drawings and TECHNICAL SERVICE BULLETINS
(registrations required)
BBB Industries Premium Alternators Starters Power Steering Products
Dec 15, 2016 | 2005 Chrysler Pacifica
Plate light does not work, but lights are good and sockets seem good
check bulb the number plate light runs on the same circuit as the side lights so if they are working its got to be a bad earth on the plate light
Jan 24, 2016 | Cars & Trucks
License plate light
very easy to replace license plate lights, two lights over plate, any auto store will have the bulbs, or mabye a fuse ?
Jan 24, 2012 | 2005 Kia Optima
How do you change the license plate bulb without removing the rear panel on 2005 nissan pathfinder?
YOU NEED REMOVE SCREWS AND PULL THE HOUSING FROM THE LIFT GATE REMOVE THE BULB HOLDER AND REPLACE THE BULB.
Sep 20, 2011 | 2005 Nissan Pathfinder
How do I access the area to replace the license plate light bulbs on a 1996 Nissan Pathfinder?
Not sure about this year, but you either remove the license plate, or else you get at it from the backside (inside the truck).
Feb 25, 2010 | 1998 Nissan Pathfinder
My license plate lights dont work help?
the bulb is most likely burned out. there are a few types of license plate lights out there. some where you have to replace the whoel unit and some that have replaceable bulbs. both you can find at your local parts store.
Jan 30, 2010 | 1990 Nissan Pathfinder
Need to replace license plate bulb on my 2005
1. Open the hatch and stand under it.
2. Remove pull handle from the inside of the hatch (2 screws under pop panels).
3. Starting in the lower corners, gently pry the entire interior panel from the hatch,
and leave it hanging from the wiper area near the glass.
4. Grasp the bulb housing and twist to the left while pressing inward.
5. Replace with a 1156 bulb.
Nov 01, 2009 | 2005 Nissan Pathfinder
I need to change the license plate bulbs on my 1992 nissan pathfinder? how do i do that? ive bought the correct bulbs already, i just need to know how to get them in
Look directly up by the plate should be to screws for each little panel . unscrew,pull bulb out and push new ones in.
Aug 16, 2009 | 1992 Nissan Pathfinder
Thule 2000 Ford Taurus - Wagon, with factory roof track - Base Rack System Logo
106 people viewed this question
Top Thule Home Experts
Donni Steen
Tom Chichester
Are you a Thule Home Expert? Answer questions, earn points and help others
