Question about AEG Microwave Ovens
Microwave does not heat the food - AEG Microwave Ovens
  • 26 Answers
SOURCE: food not heating in microwave
Magnetron tube probably failed. Depends on how old the microwave is. If its still under warranty, call Frigidaire. If not, take it to a repair shop, get an estimate, and compare it to a new one. It'll probably be cheaper to buy a newer one that will have more power, but check anyway.
Posted on Dec 18, 2008
SOURCE: Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
heatman101
  • 43501 Answers
SOURCE: GE Microwave JVM1850 Does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jjs
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: My microwave is not heating food?
heatman101
dghj
heatman101
  • 43501 Answers
SOURCE: Microwave not heating food. What should I chedk?
heatman101
hgdjdg
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Microwave not heating any food
Basic Microwave Oven TroubleshootingTips
heatman101-0=-0
May 10, 2010 | Maytag MMV4205 Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Our microwave (GE) not longer heats food items.
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
