Question about GE PYE23PSDSS French door
REMOVE PADDLE WHERE ARE SCREWS FOR PADDLE
Remove loose change from washing machine
Depends where the loose change is? Some times it caught between the middle paddle and the basket.Tthat I just use a small flat tip screw driver and finger, trap it and lift carefully out. If the coins are underneath the basket then its more involved. First, tape the door down and lift top cap and prop up aside. Then remove tubs cap off of tub. Next inside basket in the center, remove center cap off of paddle. Then remove bolt from center. Remove paddle." This I use a screw driver small enough to fit in paddle holes, one on each side to lift equally,back and forth." You will find six phillips head screws under paddle you need to remove. This should be able to lift the basket out. Walla!! T
here's the bottom of the tub and anything lying there should be removed. If you want to really inspect it there are two 5/16th head screws that hold a protective plastic plate that should be removed and checked sense your there any ways. good luck to you and hope this helps.
Feb 21, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
How do I repair/replace the ice dispensing paddle? Mine broke in half! I have a Frigidaire FRS26H5ASB4
The panel comes off some snap off others have a couple screws hidden under the drip tray. After removing the outer panel, you will see some screws holding the paddle in place.
Sep 24, 2014 | Frigidaire FRS26H5AS Side by Side...
How to fix when your paddle is stuck on your cuisinart stand up mixer
The shaft of the paddle is bent. After frustrating discussions with Cuisinart customer service, I was able to free my paddle. First, you will notice that the paddle screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new paddle.
Jul 12, 2014 | Cuisinart Food Mixers
Paddle came off inside dryer drum I need to open the top so I can put more screws in
remove 4 screws around the door perimeter,remove door,then the front panel will pull off towards you then remove 2 hex headed screws just under where the top and front covers meet,then you can raise the top to replace baffle/paddle screws
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
One blade does not turn
The left blade on a BD 2300 bread maker did not turn when neading the dough. I took it apart by removing the six screws in the bottom of the case and the screws inside around the bottom outer edges of the metal insert. I then removed the screws holding the motor assembly to the base. I found that the metal plate attached to the paddle shaft driven by the gear had torn through the plastic gear, and was no longer driving the paddle. I made a new plate with the end bent down 90 degrees so that it fitted into a slot in the plastic gear. This is much stronger and the breadmaker now works fine. This is a weakness in the design and the failure could occur on either paddle. failures of the left paddle could be due to the toothed belt breaking, this drives from the right paddle gear. There is also a belt between the motor and the left paddle gear.
Dec 14, 2009 | Black & Decker B2300 Bread Machine
Broken water paddle
remove the bottom pan by pulling it out, then you will see three screws. remove the screws. Push the fram up which will unlatch it. The asbly will now come out. pull the water hose and the electrical connector, and you'll see the screws that hold the paddle.
Aug 12, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Broken water paddle
be sure to unplug the refrigerator.
remove the drip tray by sliding it forward.. then remove two screws . slide the dispencer cover up two screw hold in the control remove water line two screws hold in water paddle. remove paddle and wire.
to replace water line use a long screw driver to push back into cover. make sure it extends bellow outlet..
hope it helps
Aug 08, 2008 | Frigidaire FRS26R4A Side by Side...
The paddle came off inside my Neptune Dryer
The screws for the paddle can be accessed by removing the small back panel. If they are stripped out you will need a new paddle.
Jun 07, 2007 | Maytag Neptune MDE5500AY Electric Dryer
GE PYE23PSDSS French door Logo
37 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
