Question about Nokia 6600 slide Cellular Phone
Earphone plug seems too big
I have upgraded to a nokia 6600. Earphones were included in box but plug seems too big to fit in the point where the charger goes. Am i just being completely stupid or is there another point where the earphones connect??
  • 36 Answers
Yes there should be another lead that they plug into. or whoever you bought it from may have sent the wrong bundled accessories.
Posted on Jun 19, 2009
How can I plug earphones into this - which plug do you use?
Unless it has a plug for earphones it will not be an easy task. Most tvs only have line out (no volume control) or speaker out (rare) to plug in external speakers. Speaker outputs would be much to high to try earphones with. Line out will probably work but with no volume control unless you have it built into your earphones. You will also need an adapter to use the earphones with the line out.
Sep 09, 2015 | Televison & Video
Can i listen to fm radio without using earphones?
It will be depends on your mobile brand....
Jun 30, 2011 | Cell Phones
Whenever i plug my earphones into my mp3 player I cannot hear my music through the earphones. any idea what the issue could be?
The wire inside the earphones Tore. If these earphones came with the Player then they are probably not very strong earphones. Usually the name brand ones are more durable. I believe it is time for you to buy some new earphones.
Dec 29, 2010 | Philips GOGEAR SA6045 MP3 Player
The MP3 player earphones only work sometimes. Left will work the right doesn't, the right works the left doesn't. Somethimes if you move the MP3 player, neither one of the speakers work. We purchased new...
Sounds as though either the earphone's Plug isn't the right size or plug end shape... OR the actual Jack is faulty, and only making intermittent connections... or the wire to them is broken. What is best is take the MP3 unit along when buying any head/earphones and try them in shop.. As for Walmart... Talk to a manager and demand a refund or a change of type... Don't take NO for an answer. Also you don't need to spend that amount for them... any cheap pair that works will be OK. Try before you buy.
Feb 02, 2010 | Audio Players & Recorders
Well i have green and black skull candy earphones and the one earphone just died on me today i've trying banging it but that didnt work and I fear I might have made it worse how can I fix it?
It usually isn't the ear bud that fails. It's the wire at the plug. Best bet is to buy a new plug on the end of the cord after cutting the last inch or so off. I recommend 90degree plugs if possible
Nov 12, 2009 | Skull Candy LINK Earbuds Consumer...
My nokia 6230i no sound and seems to have an earphones symbol set
open it up completely...where the charging socket is at the bottom use a toothbrush and some alcahol ...theres dust and fluff shorting out the pins inside ....had this problem before...if you plug in an earphone(handsfree) it should work...
Nov 03, 2009 | Nokia 6230i Cellular Phone
When ever I look at a video on my laptop I can hear the sound good but when i plug my earphones up it sounds funny u can hear them talk but it sounds funny i upgraded my sound still no change my earphones...
Hi, It seems the sound card might be defective, if you tested with some known good earphones in the computer, and you still have the same sound quality, then it might need to be replaced, HP should have diagnostics software within the computer, if you're able to access it to diagnose the ocmputer please do so, otherwise if your warranty is still valid with HP you should be able to contact them for a replacement or troubleshooting.
May 04, 2009 | HP Pavilion dv9000z Notebook
Won't detect a jack being plugged in
it doesen`t do that on my computer either but i still get sound
Apr 13, 2009 | Dell A215 Computer Speakers
Ipod nano 2ndG one headphone out
Sometimes if the plug of earphones are inserted half way, only one of the earphones play. Please try to remove and insert again and see to that it is fitted in properly and completely.
Cheers.
Aug 03, 2008 | Apple iPod nano
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Nokia 6600 slide Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
